Increment a menu from an analog read
Hello to all,
I have one question which is bugging me from some time.
I have found this menu on the internet and I want to increment it from a value which is read from an analog input or from a fixed one, does not matter. For example on the motor voltage parameter i want to start from 230 for example not from 0.
I cannot wrap my head around this and I did not find any solution to this.
Thank you in advance!
#include <LiquidCrystal.h>
LiquidCrystal lcd(6, 7, 5, 4, 3, 2);
//Input & Button Logic
const int numOfInputs = 4;
const int inputPins[numOfInputs] = {8,9,10,11};
int inputState[numOfInputs];
int lastInputState[numOfInputs] = {LOW,LOW,LOW,LOW};
bool inputFlags[numOfInputs] = {LOW,LOW,LOW,LOW};
long lastDebounceTime[numOfInputs] = {0,0,0,0};
long debounceDelay = 5;
//LCD Menu Logic
const int numOfScreens = 10;
int currentScreen = 0;
String screens[numOfScreens][2] = {{"Motor Voltage","Volts"}, {"Motor Current", "Amps"},
{"Motor Rated HP","HP"},{"Overload Temp.","degC"}, {"Accel Time", "Secs"}, {"Restart Time","Mins"},
{"Analog Out. Curr.","mA"},{"Input Temp.","degC"}, {"Run Time", "Hours"}, {"Start Times","times"}};
int parameters[numOfScreens];
  for(int i = 0; i < numOfInputs; i++) {
    pinMode(inputPins[i], INPUT);
    digitalWrite(inputPins[i], HIGH); // pull-up 20k
  //Serial.begin(9600);
  lcd.begin(16, 2);
  setInputFlags();
  resolveInputFlags();
void setInputFlags() {
    int reading = digitalRead(inputPins[i]);
    if (reading != lastInputState[i]) {
      lastDebounceTime[i] = millis();
    if ((millis() - lastDebounceTime[i]) > debounceDelay) {
      if (reading != inputState[i]) {
        inputState[i] = reading;
        if (inputState[i] == HIGH) {
          inputFlags[i] = HIGH;
    lastInputState[i] = reading;
void resolveInputFlags() {
    if(inputFlags[i] == HIGH) {
      inputAction(i);
      inputFlags[i] = LOW;
      printScreen();
void inputAction(int input) {
  if(input == 0) {
    if (currentScreen == 0) {
      currentScreen = numOfScreens-1;
    }else{
      currentScreen--;
  }else if(input == 1) {
    if (currentScreen == numOfScreens-1) {
      currentScreen = 0;
    }else{
      currentScreen++;
  }else if(input == 2) {
    parameterChange(0);
  }else if(input == 3) {
    parameterChange(1);
void parameterChange(int key) {
  if(key == 0) {
    parameters[currentScreen]++;
  }else if(key == 1) {
    parameters[currentScreen]--;
void printScreen() {
  lcd.clear();
  lcd.print(screens[currentScreen][0]);
  lcd.setCursor(0,1);
  lcd.print(parameters[currentScreen]);
  lcd.print(" ");
  lcd.print(screens[currentScreen][1]);
It sounds like you need to read the analogue input and translate it to a value between 0 and 9 in order to use it as an index to the screens array.
If that is what you want then consider using the map() function
map() function
byte menuIndex = (analogRead(analoguePin),0, 1023, 0, 9);
Than you very much for the response but maybe I did not explain myself very good.
I want to start incrementing the parameter on one screen from the array, does not matter which not from 0 but from 230 for example.
So it will be "Motor Voltage 230" and if I press the buttons increment to 231 or decrement to 229.
Thanks is advance!
So set the initial value of the parameter to 230 instead of zero. Where in your code is the initial value of the parameters set ?
It looks like it is here
If so then give each of the levels of the parameters array a starting value
Could you please explain me a little better how can I achieve this?
Thanks!
vlad00000:
Thanks!
The same way that other arrays are defined
int parameters[numOfScreens] = {230, 123, 456, 321, 654, 999, 101, 102, 111, 222};
Thank you very much for all the help.
It worked!
Thanks again!
