i have an integer set to 0, inside of an interrupt i have the integer increment by 1 (num++; the integer is named num). then i output the integer to the serial monitor is shows 0 but when i press the button it goes up by 2 instead of 1. please help me
Help you with what?
bradleys:
Is the input debounced ?
Have you got a pullup or pulldown resistor in place on the input ?
bradleys:
please help me
Certainly. Read this. You will find lots of good advice there.
UKHeliBob:
neither of these seemed to work. they skipped all of the if statements
It's time for you to post the code that causes the problem
