increment by bitwise
Hey! Sorry if this has been discussed. Maybe I don't have the right keywords.
Is it not possible to increment by a bit shifted value? The code below works fine if I change it to onePossibility++; But +=n<<1 does not augment the variable at all.
I want to keep track of three possible movements of four entities, stored neatly in three bytes.
for(int n = 0; n<4; n++)
    if( var > 1)
       {onePossibility+=(n<<1);}
    if(var< 1)
       {anotherPossibility +=(n<<1);}
    if(var == 0)
       {aThirdPossibility +=n(<<1);}
Thanks!!
peterbradley:
The code below works fine...
That is impossible. Your code cannot possibly make it through the compiler. For many reasons.
I suggest you first get the syntax errors fixed. Adding setup and loop is a great place to start.
You really should provide a sketch complete enough to compile if you want programming help.
Since '<<1' is roughly equivalent to '*2' you could just count by 2's:
for(int n = 0; n<8; n+=2)
Note that your 2nd and 3rd 'if' statements are not inside the loop. Perhaps you meant to write:
for(int n = 0; n<4; n++) {
    if( var > 1)
    if(var< 1)
    if(var == 0)
