I'm writing a code that is supposed to count how many times a button has been pressed and track it. when I run the code the output produces a large number or a large negative number instead of 1 or 2. what am i doing wrong? code :
unsigned char pb1in = 9; // for incoming serial data
unsigned char pb1value = 0;
int count = 0;
int count2 = 0;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
Serial.print("Start \n"); // let the user know the program is running
pinMode(pb1in,INPUT);
pb1value = digitalRead(pb1in); //check status of pb1
while(pb1value == 1) //wait until pb1 is pushed, the while argument becomes false when the button is pushed and pb1value is zero
pb1value = digitalRead(pb1in); //update pb1 status
count = count - 48;
count2 = count ++;
delay(10);
Serial.print("PB1 has been pushed \n");
Serial.print("The button has been pushed "); // printing amount of button pushes
Serial.print(count2);
Serial.print(" times \n");
while(pb1value == 0) //wait until pb1 is released, the while argument becomes false when the button is not pushed and pb1value is one
Serial.print("PB1 has been released \n");
Serial.print(" \n");
delay(10);
