Increment filename
Hello,
I have been trying to figure out how to change my recordings filename saved on the SD card each time it resets instead of overwriting.
It doesn't need to be the date or anything. Just something sequential, i.e. recording1.wav, recording 2.wav and so on.
I have been trying to do this for days and being new to Arduino it is slightly tricky to get my head around things.
Below is the unedited code. The naming happens about half way through.
// Include libraries
#include <SdFat.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
// SD card objects
SdFat sd;
SdFile rec;
// Constants
const int chipSelect = 10;
unsigned long fileSize = 0L;
unsigned long waveChunk = 16;
unsigned int waveType = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 22050;
unsigned long bytesPerSec = 22050;
unsigned int blockAlign = 1;
unsigned int bitsPerSample = 8;
unsigned long dataSize = 0L;
unsigned long recByteCount = 0L;
unsigned long recByteSaved = 0L;
const int ledStart = 7;
int recPressed = 0;
int stopPressed = 0;
unsigned long oldTime = 0L;
unsigned long newTime = 0L;
// Buffers
byte buf00[512]; // buffer array 1
byte buf01[512]; // buffer array 2
byte byte1, byte2, byte3, byte4;
unsigned int bufByteCount;
byte bufWrite;
// Counter
byte recordingEnded = false;
unsigned int counter;
unsigned int initial_count;
unsigned int maxCount = 5 * 1000; // 5 Seconds
void setup() { // THIS RUNS ONCE
  // Setup timer & ADC
  Setup_timer2();
  Setup_ADC();
  // Set output pins
  pinMode(10, OUTPUT);
  pinMode(ledStart, OUTPUT);
  // Init SD card
  if (sd.begin(chipSelect, SPI_FULL_SPEED)) {
    for (int dloop = 0; dloop < 4; dloop++) {
      digitalWrite(ledStart,!digitalRead(ledStart));
      delay(100);
  // If error
  else {
    while(1) {
  // Start recording
  StartRec();
  // Init counter
  initial_count = millis();
void loop() { // THIS RUNS LOTS!
  // Update counter
  counter = millis() - initial_count;
  // Stop recording if counter reached
  if (counter > maxCount && !recordingEnded) {
    recordingEnded = true;
    StopRec();
  // Update recording
  if (recByteCount % 1024 == 512 && recPressed == 1) { rec.write(buf00,512); recByteSaved+= 512; } // save buf01 to card
  if (recByteCount % 1024 == 0 && recPressed == 1) { rec.write(buf01,512); recByteSaved+= 512; } // save buf02 to card
void StartRec() { // begin recording process
  digitalWrite(ledStart,HIGH);
  recByteCount = 0;
  recByteSaved = 0;
  recPressed = 1; // recording button has been pressed
  stopPressed = 0;
  writeWavHeader();
  sbi (TIMSK2, OCIE2A); // enable timer interrupt, start grabbing audio
void StopRec() { // stop recording process, update WAV header, close file
  cbi (TIMSK2, OCIE2A); // disable timer interrupt
  writeOutHeader();
  digitalWrite(ledStart,LOW); // turn off recording LED
  recPressed = 0;
void writeOutHeader() { // update WAV header with final filesize/datasize
  rec.seekSet(4);
  byte1 = recByteSaved & 0xff;
  byte2 = (recByteSaved >> 8) & 0xff;
  byte3 = (recByteSaved >> 16) & 0xff;
  byte4 = (recByteSaved >> 24) & 0xff;
  rec.write(byte1);  rec.write(byte2);  rec.write(byte3);  rec.write(byte4);
  rec.seekSet(40);
  rec.close();
void writeWavHeader() { // write out original WAV header to file
  recByteSaved = 0;
  rec.open("PLEASECHANGEME.wav", O_CREAT | O_TRUNC | O_RDWR);
  rec.write("RIFF");
  byte1 = fileSize & 0xff;
  byte2 = (fileSize >> 8) & 0xff;
  byte3 = (fileSize >> 16) & 0xff;
  byte4 = (fileSize >> 24) & 0xff;
  rec.write("WAVE");
  rec.write("fmt ");
  byte1 = waveChunk & 0xff;
  byte2 = (waveChunk >> 8) & 0xff;
  byte3 = (waveChunk >> 16) & 0xff;
  byte4 = (waveChunk >> 24) & 0xff;
  byte1 = waveType & 0xff;
  byte2 = (waveType >> 8) & 0xff;
  byte1 = numChannels & 0xff;
  byte2 = (numChannels >> 8) & 0xff;
  byte1 = sampleRate & 0xff;
  byte2 = (sampleRate >> 8) & 0xff;
  byte3 = (sampleRate >> 16) & 0xff;
  byte4 = (sampleRate >> 24) & 0xff;
  byte1 = bytesPerSec & 0xff;
  byte2 = (bytesPerSec >> 8) & 0xff;
  byte3 = (bytesPerSec >> 16) & 0xff;
  byte4 = (bytesPerSec >> 24) & 0xff;
  byte1 = blockAlign & 0xff;
  byte2 = (blockAlign >> 8) & 0xff;
  byte1 = bitsPerSample & 0xff;
  byte2 = (bitsPerSample >> 8) & 0xff;
  rec.write("data");
  byte1 = dataSize & 0xff;
  byte2 = (dataSize >> 8) & 0xff;
  byte3 = (dataSize >> 16) & 0xff;
  byte4 = (dataSize >> 24) & 0xff;
void Setup_timer2() {
  TCCR2B = _BV(CS21);  // Timer2 Clock Prescaler to : 8
  TCCR2A = _BV(WGM21); // Interupt frequency  = 16MHz / (8 x 90 + 1) = 22191Hz
  OCR2A = 90; // Compare Match register set to 90
void Setup_ADC() {
  ADMUX = 0x65; // set ADC to read pin A5, ADLAR to 1 (left adjust)
  cbi(ADCSRA,ADPS2); // set prescaler to 8 / ADC clock = 2MHz
  sbi(ADCSRA,ADPS1);
  sbi(ADCSRA,ADPS0);
ISR(TIMER2_COMPA_vect) {
  sbi(ADCSRA, ADSC); // start ADC sample
  while(bit_is_set(ADCSRA, ADSC));  // wait until ADSC bit goes low = new sample ready
  recByteCount++; // increment sample counter
  bufByteCount++;
  if (bufByteCount == 512 && bufWrite == 0) {
    bufByteCount = 0;
    bufWrite = 1;
  } else if (bufByteCount == 512 & bufWrite == 1) {
    bufByteCount = 0;
    bufWrite = 0;
  if (bufWrite == 0) { buf00[bufByteCount] = ADCH; }
  if (bufWrite == 1) { buf01[bufByteCount] = ADCH; }
//  if (recByteCount % 1024 < 512) { // determine which buffer to store sample into
//    buf01[recByteCount % 512] = ADCH;
//  } else {
//    buf02[recByteCount % 512] = ADCH;
So you want a changing name instead of PLEASECHANGEME.wav
You say "each time it resets", but what is "it"? The arduino, the SD card?
If you want to change the name, you can declare a char array
char fileName[18] = "recording000.wav";
And you can write the number like this
sprintf (filename, "recording%03d.wav",fileNumber);
assuming the number will remain less than 1000.
If the arduino resets, then you need to save the file number in the EEPROM before the reset, and read it again at boot to increase it and create the new file name.
Thank you for the reply.
It is going to be the entire device being turned off and on again.
How would I go about with saving the last file name in the EEPROM?
Alex_osborne:
Don't bother.
Start at 0. Create the filename with sprintf(). Try to open it on the SD card. Increment the number until you find one that is not used.
Alex_osborne:
Don't save the name, just save the number. Look for tutorials on internet to learn how to use the EEPROM, depending on your board
