Hi all, i'm new to programming and i'm starting to experiment with arduino.
I am working on a project of using arduino to control the hues of RGB LEDs. I've got red on pin11, green on pin10 and blue on pin9. what i would want to achieve is to use a push button to increase the hue value of the LEDs.
I've found this set of codes on the web that uses a potentiometer (see below). was trying to change the input to digital using a pushbutton. but i'm not sure how to do it. thanks in advance!
int potpin = 5; // Potentiometer connected to analog pin 5
int rpin = 11;
int gpin = 10;
int bpin = 9;
float h;
int h_int;
int r=0, g=0, b=0;
int val=0;
void h2rgb(float h, int &R, int &G, int &B);
void setup() // run once, when the sketch starts
Serial.begin(9600); // set up Serial library at 9600 bps
void loop() // run over and over again
val=analogRead(potpin); // Read the pin and display the value
//Serial.println(val);
h = ((float)val)/1024;
h_int = (int) 360*h;
h2rgb(h,r,g,b);
Serial.print("Potentiometer value: ");
Serial.print(val);
Serial.print(" = Hue of ");
Serial.print(h_int);
Serial.print("degrees. In RGB this is: ");
Serial.print(r);
Serial.print(" ");
Serial.print(g);
Serial.print(" ");
Serial.println(b);
analogWrite(rpin, r);
analogWrite(gpin, g);
analogWrite(bpin, b);
void h2rgb(float H, int& R, int& G, int& B) {
int var_i;
float S=1, V=1, var_1, var_2, var_3, var_h, var_r, var_g, var_b;
if ( S == 0 ) //HSV values = 0 ÷ 1
R = V * 255;
G = V * 255;
B = V * 255;
var_h = H * 6;
if ( var_h == 6 ) var_h = 0; //H must be < 1
var_i = int( var_h ) ; //Or ... var_i = floor( var_h )
var_1 = V * ( 1 - S );
var_2 = V * ( 1 - S * ( var_h - var_i ) );
var_3 = V * ( 1 - S * ( 1 - ( var_h - var_i ) ) );
if ( var_i == 0 ) {
var_r = V ;
var_g = var_3 ;
var_b = var_1 ;
else if ( var_i == 1 ) {
var_r = var_2 ;
var_g = V ;
var_b = var_1 ;
else if ( var_i == 2 ) {
var_r = var_1 ;
var_g = V ;
var_b = var_3 ;
else if ( var_i == 3 ) {
var_r = var_1 ;
var_g = var_2 ;
var_b = V ;
else if ( var_i == 4 ) {
var_r = var_3 ;
var_g = var_1 ;
var_b = V ;
else {
var_r = V ;
var_g = var_1 ;
var_b = var_2 ;
R = (1-var_r) * 255; //RGB results = 0 ÷ 255
G = (1-var_g) * 255;
B = (1-var_b) * 255;
