Good Day All,
I am facing a challenge in my early days, I am attempting to keep track of a variable (Not sure what data type to declare it as) I need to send on a serial 485 communication bus to a slave device. I need to increment a message identifier that starts at 0h and rolls over at FFFFh.
The Master needs to transmit this message <010100000A, the message is broken into these sections,
< - Message Header Identifying the command is sent from the master to a slave
0101h - 4char indicating the address on the bus, first 01 is the master address and next 01 is the slave address.
0000h - is the message identifier that will be incremented when a slave answers back the masters message it will send the same identifier only then will the master increment the identifier.
0A - this is the command of the master to the slave
The slave will answer the message with this message >0101000006
The Slave needs to transmit this message >0101000006 the message is broken into these sections,
- Indicating a slave is answering to the master
0000h the message identifier of the message being answered
06h -The ACK that the message was executed
Should the master not receive a answer from the slave it will resend the same transaction until it receives a ACK, this is the code I have wrote but the results does work as I need it.
#include <TimerOne.h>
#define Tx485 2
char masterSOH = '>';
char slaveSOH = '<';
char masterAddress[] = "01";
char slaveAddress[] = "01";
unsigned int MessageIdentifier = 0X00;
unsigned int MessageIdentifierRollober = 0xFFFF;
int IncPoll;
int CalcIdentifier(){
MessageIdentifier++;
if (MessageIdentifier == 0xFFFF)
MessageIdentifier = 0;
Serial.println(MessageIdentifier,HEX);
return(MessageIdentifier);
void Poll(){
digitalWrite(Tx485,HIGH);
digitalWrite(3,HIGH);
_delay_ms(5);
Serial1.write(masterSOH);
Serial1.write(masterAddress);
Serial1.write(slaveAddress);
Serial1.write(MessageIdentifier);
Serial1.write(0x0A); //Command
_delay_ms(1);
digitalWrite(Tx485,LOW);
digitalWrite(3,LOW);
_delay_ms(2);
void TimerTick(){
CalcIdentifier();
Poll();
pinMode(Tx485,OUTPUT);
pinMode(3,OUTPUT);
Serial.begin(38400);
Serial1.begin(38400);
Timer1.initialize(1000000);
Timer1.attachInterrupt(TimerTick);
The result of the Serial.write(MessageIdentifier); is, What I expect is:
1 0001
2 0002
3 0003
4
5
6
7
8
9
A
B
C… 000C
Please advise how I can achieve this,
