The issue from what I posted yesterday is solved now.
Here is my revised code. I hope the code is alright now. I also change the baudrate from 300 to 9600
#include <FastLED.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
#define LED_PIN_1 5
#define NUM_LEDS_1 27
#define LED_PIN_2 8
#define NUM_LEDS_2 6
#define BRIGHTNESS 40
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
CRGB leds_1[NUM_LEDS_1];
CRGB leds_2[NUM_LEDS_2];
// This example shows several ways to set up and use 'palettes' of colors
// with FastLED.
// These compact palettes provide an easy way to re-colorize your
// animation on the fly, quickly, easily, and with low overhead.
// USING palettes is MUCH simpler in practice than in theory, so first just
// run this sketch, and watch the pretty lights as you then read through
// the code. Although this sketch has eight (or more) different color schemes,
// the entire sketch compiles down to about 6.5K on AVR.
// FastLED provides a few pre-configured color palettes, and makes it
// extremely easy to make up your own color schemes with palettes.
// Some notes on the more abstract 'theory and practice' of
// FastLED compact palettes are at the bottom of this file.
long count = 0;
float ampvalue = 0;
uint8_t ghue=128;
uint8_t ghue2=128;
uint8_t ghuedelta = 15;
static float switchstate = 0;
unsigned long prevmillis=0;
unsigned long prevmillis1=0;
unsigned long prevmillis2=0;
unsigned int x = 0;
unsigned int y = 0;
unsigned char set=0;
FastLED.addLeds<LED_TYPE, LED_PIN_1, COLOR_ORDER>(leds_1, NUM_LEDS_1).setCorrection( TypicalLEDStrip );
FastLED.addLeds<LED_TYPE, LED_PIN_2, COLOR_ORDER>(leds_2, NUM_LEDS_2).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
fill_solid(leds_2, NUM_LEDS_2, CHSV(ghue2,255,255));
fill_solid(leds_1, NUM_LEDS_1, CHSV(ghue,255,255));
FastLED.show();
delay(3000);
while (!Serial) {
// will pause Zero, Leonardo, etc until serial console opens
delay(1);
uint32_t currentFrequency;
Serial.println("Hello!");
// Initialize the INA219.
// By default the initialization will use the largest range (32V, 2A). However
// you can call a setCalibration function to change this range (see comments).
if (! ina219.begin()) {
Serial.println("Failed to find INA219 chip");
while (1) {
delay(10);
// To use a slightly lower 32V, 1A range (higher precision on amps):
//ina219.setCalibration_32V_1A();
// Or to use a lower 16V, 400mA range (higher precision on volts and amps):
//ina219.setCalibration_16V_400mA();
Serial.println("Measuring voltage and current with INA219 ...");
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
float power_mW = 0;
current_mA = ina219.getCurrent_mA();
//switchstate=analogRead(A0);
//ampvalue=current_mA;
//ampvalue = abs(map(current_mA, 0, 2000, 0, 100));
unsigned long currentmillis2=millis();
if (currentmillis2-prevmillis2>=10000){
prevmillis2=currentmillis2;
fill_solid(leds_2, NUM_LEDS_2, CHSV(ghue2+=ghuedelta,255,255));
EVERY_N_MILLISECONDS(20000){
set+=1;
if(set>3){
set=0;
if (current_mA > 400) {
unsigned int speed = abs(map(current_mA,400,2000,1,200));
switch(set){
case 0:
Running_LED(speed);
case 1:
Progressing_LED(speed);
case 2:
Cumulation_LED(speed);
case 3:
Rainbow_LED(speed);
FastLED.show();
Serial.println(set);
else if (current_mA> 100) {
while ((current_mA > 100) && (current_mA < 400)) {
for (int i = 0; i < 255; i++) {
//leds[i]=CRGB::Aqua;
fill_solid( leds_1, NUM_LEDS_1, CHSV(128, 255, i));
FastLED.show();
delay(500 / 255);
for (int i = 255; i > 0; i--) {
FastLED.show();
delay(500 / 255);
//unsigned long currentmillis=millis();
//if (currentmillis-prevmillis>=10000){
// prevmillis=currentmillis;
// fill_solid(leds_2, NUM_LEDS_2, CHSV(ghue2+=ghuedelta,255,255));
//count=count-10;
//Serial.print("switchstate: ");Serial.println(switchstate);
//Serial.println("Idle State");
//Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
//Serial.print("Value: "); Serial.println(ampvalue);
//ampvalue = current_mA;
else {
for (int i = 0; i < NUM_LEDS_1; i++) {
leds_1[i] = CRGB::CRGB::Black;
FastLED.show();
//Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
void Running_LED(unsigned int &speed){
leds_1[x] = CHSV(ghue, 255, 255);
leds_1[i].fadeToBlackBy(5);
int interval = speed;
if(currentMillis - prevmillis > interval) {
prevmillis=currentMillis;
x++;
if (x>=NUM_LEDS_1){
fill_solid(leds_1,NUM_LEDS_1,CRGB::Black);
x=0;
ghue += ghuedelta;
void Progressing_LED(unsigned int &speed){
for (int i = 0; i < x; i++) {
leds_1[i] = CHSV(ghue, 255, 255);
x++;
//fill_solid(leds,x,CHSV(ghue, 255, 255));
if (x>=NUM_LEDS_1){
x=0;
y+=1;
if (y>1){
ghue += ghuedelta;
y=0;
void Cumulation_LED(unsigned int &speed){
leds_1[i].fadeToBlackBy(8);
int interval = speed/2;
x++;
if (x>=NUM_LEDS_1-y){
y+=2;
x=0;
if (y<NUM_LEDS_1){
for (int j=0;j<y;j++){
leds_1[NUM_LEDS_1-y+j]= CHSV(ghue,255,255);
}else{
ghue+=(255/4);
y=0;
void Rainbow_LED(unsigned int &speed){
for (int i = 0; i < NUM_LEDS_1; ++i) {
leds_1[i] = CHSV(ghue - (i * 255/NUM_LEDS_1), 255, 255);
//You can change the pattern speed here
int interval = 10;
ghue+=(speed/75);
On the side note. With baud rate 300, function Running LED also left me with 1 last led off and Progressing LED with 2 last leds off. When I change to 9600, the last problem is function Progressing LED 1 last led always off.
Could you suggest what is wrong with this? I hope the LED Strip would run all the way until the very last number of led.
