increment
there are two ways to increment a variable.
x++ and ++x
reading this : https://www.arduino.cc/en/Reference/Increment
it says that
++x will increment x by 1 and show that value. but x++ will show the initial value of x ..
if that is the case, then when, or where in the loop, does x become incremented ?
Well in a loop you usually have this
for (int i = 0; i<10; [b]i++[/b]) {}
or
for (int i = 0; i<10; [b]++i[/b]) {}
so the increment is a statement by itself, so it does not matter
but if you do
int a,b,i;
i = 5;
a = i++; // a is 5, i is 6
b = ++i; // b is 6, i is 7
The two forms determine the order of execution.
++X means increment the value of X then use it's new value.
X++ means use present value of X then increment it's value.
The notation is two operations with variable order.
Poor phrasing. Each operation [u]returns[/u] a value. See http://stackoverflow.com/questions/4445706/post-increment-and-pre-increment-concept
Often with questions like this, it’s easiest to write a short program and find out yourself. Using J-M-L’s example:
  int a,b,i;
  i = 5;
  a = i++;              // Confirm that a receives the value of i before the increment
  Serial.print("a = ");
  Serial.print(a);
  Serial.print("   i = ");
  Serial.println(i);
  i = 5;                // reset i
  b = ++i;              // Confirm that b receives the value of i after the increment
  Serial.print("b = ");
  Serial.print(b);
  Serial.println(i);
thanks.
it appears that the value is changed at the end of the line. thanks for the idea of doing a simple sketch
 int a,b,i=5;
Serial.println (i++);       // prints 5 = value of i before incrementing
Serial.println (i);         // prints 6
i++;
Serial.println (i);         // prints 7 = value because increment has occured
a = i++;
Serial.println (i);         // prints 8
b = ++i;
Serial.println (i);         // prints 9
Serial.println (b=++i);     // prints 10 = value of equation
jremington: Poor phrasing. Each operation [u]returns[/u] a value. See http://stackoverflow.com/questions/4445706/post-increment-and-pre-increment-concept
thanks for the link. what I was missing was what was termed sequence point in that link.
in my example, it would be ; at the end of the line.
in the link they offer :
(i++ > 0) && someProperty(myArray[i])
and offer that && becomes a sequence point at which time i has been incremented.
