First time posting...here goes
I have been trying to make a hardware counter for an encoder for a while, basically I want to not rely on the Arduino to capture the pulses, I was thinking there must be a way to count pulses with a counter chip and poll it periodically with the Arduino. I found this site:
http://www.thebox.myzen.co.uk/Workshop/Rotary_Max.html
He uses an inverter, a couple of gates, latch, and a counter chip to count pulses. I assembled the circuit on my breadboard, and am having an issue.
The counter (74hc193) has a 4 bit output, I connected the 4 bits to LEDs and am turning the encoder slow enough to see the individual pulses change the LEDs. When I rotate CW its fine I can count along with it as I turn the encoder (5,4,3,2,1,15,14,13.....). When I rotate CCW, it is acting strange, it counts 1,2,1,3,4,3,5,6,5,7,8,7,9,10,9,11....or in binary: 0001 0010 0001 0011 0100 0011 0101 0110 0101 0111 1000 0111 1001 1010 1001 1011 and so on.
Looks like two steps forward and one back. I am using the HC series of chips instead of LS since that is what I had. I've tried several things to correct the counting up, I wrote a small sketch and used the Arduino to simulate the A and B phases instead of an encoder, I've added capacitors to isolate each chip, swapped new chips, and same response each time....I'm stumped, anyone have any ideas? I can post a few pics of my setup if it's of any use.
Cheers, -Dave
