I am working on a project where I need to apply an incremental voltage (0.1V, 0.2V, 0.3V) to a system. The voltage should periodically increment due to the code.
I want to use the Arduino Uno to provide this voltage, but I'm starting to think that it isn't possible.
Does anyone have any suggestions on how this could be done, period.
You could try a low-pass filter on a PWM output. If you configured the PWM to use a higher frequency, say 31250Hz, then use the following values ... R = 470Ω, C = 10µF, you would get:
