Incremental quadrature encoders DOUBLE
Hello community,
I am using a code I found in playground to measure the ticks of an incremental encoder I have on a motor.
I am monitoring channel A and B. At the datasheet the manufacturer states that the encoder give 500 pulses per rotation. With my code I see exactly 1000 counts per motor rotation.
Is it because I measure A channel in regards to B?
Should I measure A in regards to Ground?
The encoder as I said is a 5 volt incremental quadrature encoder with 8 cables, 500pulses/rotation.
5V, GND, A,B,A/,B/,I,I/
Code Attached
// Read two Quadrature Encoders
const int encoder1PinA = 2;  // encoder 1 on pins 2 and 4
const int encoder1PinB = 4;
volatile int encoder1Pos = 0;
const int encoder2PinA = 3; //encoder 2 on pins 3 and 5
const int encoder2PinB = 5;
volatile int encoder2Pos = 0;
 Serial.print("Detecting Channels");
 attachInterrupt(0, doEncoder1, CHANGE);  // encoder pin on interrupt 0 (pin 2)
 attachInterrupt(1, doEncoder2, CHANGE);  // encoder pin on interrupt 1 (pin 3)
 int Pos1, Pos2;
 static int oldPos1, oldPos2;
 uint8_t oldSREG = SREG;
 cli();
 Pos1 = encoder1Pos;
 Pos2 = encoder2Pos;
 SREG = oldSREG;
 if(Pos1 != oldPos1){
    Serial.print("A,B CH=");
    Serial.println(Pos1,DEC);
    oldPos1 = Pos1;
 if(Pos2 != oldPos2){
    Serial.print("A/,B/ CH=");
    Serial.println(Pos2,DEC);
    oldPos2 = Pos2;
void doEncoder1()
 if (digitalRead(encoder1PinA) == digitalRead(encoder1PinB))
   encoder1Pos++;    // count up if both encoder pins are the same on pin change interupt
   encoder1Pos--;    //count diown if pins are different
void doEncoder2()
 if (digitalRead(encoder2PinA) == digitalRead(encoder2PinB))
   encoder2Pos++;    // count up if both encoder pins are the same on pin change interupt
   encoder2Pos--;    //count diown if pins are different
Now you count both when the signal gets HIGH and when it falls LOW again. That will happen exactly twice as many times as there are pulses.
septillion:
Wow! Spot on mate!
I will change it to RISING and I will have a look on the readings
