Incremental Rotary Encoder 400P/R
Hi guys !
I have a rotary encoder,samethink like this
http://www.ebay.com/itm/Encoder-400P-R-Incremental-Rotary-Encoder-400p-r-AB-phase-encoder-6mm/121355244021?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27538%26meid%3D0518b865ab324b72b2f5447b0b43d145%26pid%3D100005%26prg%3D11353%26rk%3D1%26rkt%3D6%26sd%3D221379149398&rt=nc
I would like to display on LCD the number of pulses after title "LEG".
i have try this code
/* Read Quadrature Encoder
  * Connect Encoder to Pins encoder0PinA, encoder0PinB, and +5V.
  * Sketch by max wolf / www.meso.net
  * v. 0.1 - very basic functions - mw 20061220
const int poten_pin=0;
int Input_val=0;
 int encoder0PinA = 8;
 int encoder0PinB = 9  ;
 int encoder0Pos = 0;
 int encoder0PinALast = LOW;
 int n = LOW;
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
   lcd.begin(16, 2);
   pinMode (encoder0PinA,INPUT);
   pinMode (encoder0PinB,INPUT);
   Serial.begin (9600);
   lcd.setCursor(0, 1);
   lcd.print("LEG:");
   lcd.setCursor(0, 0);
   lcd.print("DEG:");
   Input_val=analogRead(poten_pin);
   n = digitalRead(encoder0PinA);
    lcd.setCursor(4, 0);
     lcd.print(Input_val);
   if ((encoder0PinALast == LOW) && (n == HIGH)) {
     if (digitalRead(encoder0PinB) == LOW) {
       encoder0Pos--;
       encoder0Pos++;
     Serial.print (encoder0Pos);
     Serial.print ("/");
     lcd.setCursor(4, 1);
     lcd.print(encoder0Pos);
      delay(5);
   encoder0PinALast = n;
seems to work fine when i rotate very slow.But when speed up dont count or lose count.
You think 400P/R are too many for arduino or i can do somethink with the code?
thanks
What happens is just what is to be expected. Your code blocks the cpu so that it is missing pulses. There are a number of culprits here.
The analog read
The serial and lcd print commands
The delay()
All of these are quite time consuming
hi
you have to use the interrupts pin 2 and pin 3
stefa24:
hi
that do you mean interrupts pin 2,3 i cant use pin 8,9 that i want ?
can you post me an example?
thanks for replay!
hi
arduino's playground can show you some example
http://playground.arduino.cc/Main/RotaryEncoders
you can try this simple sketch
//valido per contare con interrupt
//#include <LiquidCrystal.h>
//LiquidCrystal lcd(9, 8, 7, 6, 5, 4);
#define encoder0PinA 2
volatile int count, countold;
  count = 0;
  countold = 0;
  //lcd.begin(16,4); // set up the LCD's number of columns and rows:
  // statosensore1=HIGH;  //stato iniziale del sensore
  pinMode(encoder0PinA, INPUT_PULLUP);
  attachInterrupt(0, sensore1, FALLING); //sensore induttivo collegato al pin 2
  //   lcd.clear();
  Serial.begin(115200); // initialize serial communication:
  if (countold != count)
    //lcd.home();
    //lcd.print(count);
    //delay(500);
    Serial.println(count);
    //lcd.clear();
    //lcd.print(count);
    countold = count;
void sensore1()
  count++;
stefa24:
hi
i saw what you mean.
tryed pin 2 and 3.Now i can turn it little faster.
stefa24:
hi
Arduino Playground - HomePage
  count = 0;
  countold = 0;
  //  lcd.clear();
//lcd.home();
    //lcd.print(count);
    //delay(500);
    //lcd.clear();
    //lcd.print(count);
    countold = count;
void sensore1()
  count++;
thanks for replay
your code is fast enough,but only count plus!
I use that code only to test the encoder
stefa24:
coul you suggest me an example or code that full works?
I have never used all encoder signal.
Did you see the arduino's playground?
below a sketch from playground
Interrupt Example (the Encoder interrupts the processor). Uses both Interrupt pins
Code for reading encoder using 2 interrupts on pin 2 & pin3
Note: the code below uses 2 interrupts to read the full resolution of the encoder. The code above used 1 interrupt. It read half the resolution by only checking EncoderPin A for position, but it freed up an interrupt pin.
#define encoder0PinB 3
volatile unsigned int encoder0Pos = 0;
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
// encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
void loop(){ //Do stuff here }
void doEncoderA(){
  // look for a low-to-high on channel A
  if (digitalRead(encoder0PinA) == HIGH) {
    // check channel B to see which way encoder is turning
      encoder0Pos = encoder0Pos + 1;         // CW
    else {
      encoder0Pos = encoder0Pos - 1;         // CCW
  else   // must be a high-to-low edge on channel A
    if (digitalRead(encoder0PinB) == HIGH) {
    else {
  Serial.println (encoder0Pos, DEC);
  // use for debugging - remember to comment out
void doEncoderB(){
  // look for a low-to-high on channel B
   // check channel A to see which way encoder is turning
    else {
  // Look for a high-to-low on channel B
  else {
    if (digitalRead(encoder0PinA) == LOW) {
    else {
stefa 24 thank you for replays
tryed some code from playground but still lose steps
code you post,when turn minus start count from 65534
64535
64536
also when go little faster for one time then program stop working.
any ideas?
If you are using unsigned 16 bit integers, then -1 is the same as 65535. If this is going to be a problem for you, then use signed integers.
Did you remember to comment out the serial print?
Paulcet:
thanks for replay
sorry but i cant understand "comment out the serial print"
could you help a bit?
thanks
try
//Serial.println (encoder0Pos, DEC);
I posted this code in another thread. It might help you.
const char encTable[16] ={0, 1, -1, -0, -1, 0, -0, 1, 1, -0, 0, -1, -0, -1, 1, 0};//gives -1, 0 or 1 depending on encoder movement
byte encState;//remembering the encoder output and acting as index for encTable[]
byte inp;
volatile long actPos;//encoder position
void setup(){
    attachInterrupt(0, updateEnc, CHANGE);//monitor pin 2
    attachInterrupt(1, updateEnc, CHANGE);//monitor pin 3
}//setup()
void loop(){
  Serial.println(actPos);//report positioin twice a second
}//loop()
void updateEnc(){
  encState = ((encState<<2)|((PIND>>2)&3))&15;//use encoder bits and last state to form index
  actPos += encTable[encState];//update actual position on encoder movement
}//updateEnc()
Hi nilton61
thank for replay.
the code work very nice,its fast enought.
thanks a lot.
