Incrementally blinking led light after certain amount of time
If you are allowed to use external libraries, you could grab TDuino from github, and use something like this:
#include <TDuino.h>
#define LED_PIN LED_BUILTIN
#define LED_FLASH_TIME 1000
#define BLINK_INTERVAL 600000
void timerCallback(byte timerId); //Forward declaration
unsigned int numBlinks = 1; //Number of blinks
TTimer timer(timerCallback); //Timer used for timing
TPinOutput led(LED_PIN); //PinOutput used for blinking
  //Set the LED to pulse with the specified interval for "numBlinks" times
  led.pulse(LED_FLASH_TIME, numBlinks);
  //Increment number of blinks for next time
  numBlinks++;
  //Setup objects
  timer.setup();
  led.setup();
  //Set the timer to trigger for each 10 minutes, 0 = repeat forever
  timer.set(BLINK_INTERVAL, 0);
  //Loop objects
  timer.loop();
  led.loop();
The code is untested, so it may not work at all :slight_smile:
