Incubator project. stepper motor help.
Hi All !
I´am building an egg incubator using arduino to control the Temperature + Humidity + Egg rotation .
What i have:
Arduino ks0240 EASY plug controller
ks0034 DHT11 Temperature and Humidity Sensor
ks0137 EASY plug 1602 I2C Module (Displaying temperature in celsius, humidity % )
ks0140 5V Stepper Motor
4-channel Relay Module for Arduino ( 1º channel controls heater , 2º channel controls fan , 3º channel controls humidificator , 4 channel is empty)
After reseaching the forum and learning a bit i now can control the temperature an humidity to the levels i would like , but i don´t know how to control the Stepper motor to rotate 60 degrees every 60 minutes so the egg will rotate.
Study´s show that if the egg is rotated ~60 degress every 60 minutes there´s an 80% increase of hatching.
How can i accomplish this task?
Thanks !
What have you tried? Do you have the stepper driving hardware ready?
Count how many steps you have in 60 degrees. Then calculate the time per step (i.e. 60 minutes / #steps).
On the software side of, just start a timer (à la Blink Without Delay) with the delay you calculated previously, and take a step each time.
Pieter
Pieter
Have you looked at this?
