Hi. I have a arduino mega connected to index rgb led strip . The fact is that the connectors and works properly. turn on and off the LEDs I want but while running a few minutes go crazy and it do not respond. The code is ok because I try and test the codes and woks same. .
thanks
It's hard to "sell" you the right tire when we don't know which "car" you're driving, many different ones exist. The more info you give, the easier it is to help you solve your problem.
Which strip do you use, which extra components did you use, do you have a schematic of your project and could you share your code ?
