I was trying something bigger when I hit a wall trying to 2D index PROGMEM.
The results prints out to Serial Monitor, tested on an UNO.
I don’t really know why the first method does not work, hoping that someone does.
Being able to index as the first way tries would be more beginner friendly.
byte flashData; // to read one table entry into at a time
byte indexI, indexJ; // these will do the job of 2 nested for-loop indexes
const byte PROGMEM PROGTBLDIMENS[ 2 ] = // table size and table both kept in flash
10, 10
const byte PROGMEM PROGTBL[ 10 ][ 10 ] = // this example data made for easy-check results
1, 11, 21, 31, 41, 51, 61, 71, 81, 91,
2, 12, 22, 32, 42, 52, 62, 72, 82, 92,
3, 13, 23, 33, 43, 53, 63, 73, 83, 93,
4, 14, 24, 34, 44, 54, 64, 74, 84, 94,
5, 15, 25, 35, 45, 55, 65, 75, 85, 95,
6, 16, 26, 36, 46, 56, 66, 76, 86, 96,
7, 17, 27, 37, 47, 57, 67, 77, 87, 97,
8, 18, 28, 38, 48, 58, 68, 78, 88, 98,
9, 19, 99, 39, 49, 59, 69, 79, 89, 99,
10, 20, 30, 40, 50, 60, 70, 80, 90, 100
Serial.begin( 115200 ); // getting the serial queue to empty quicker
Serial.println( "\n Example of 2D Data Iteration\n" );
Serial.println( " Trying by indexing PROGMEM directly, doing something wrong!" );
for ( indexJ = 0; indexJ < 10; indexJ++ )
for ( indexI = 0; indexI < 10; indexI++ )
flashData = pgm_read_byte( PROGTBL[ indexJ ][ indexI ] );
Serial.print( flashData, DEC );
Serial.print( " " );
if ( ! (( indexI + 1 ) % 10 )) Serial.println( );
Serial.println( "\n" );
// PGM_P Addr; // define a const prog_char pointer named Addr
// Addr = (const prog_char *) PROGTBL; // cast the table address to fit Addr
Serial.println( " Using pointer into PROGEMEM works" );
flashData = pgm_read_byte( (const prog_char *) PROGTBL + indexI + indexJ * 10 );
