indexOf does not work with a string value?
Simple server code that uses indexOf and the memory saving F() macro for the static strings.
//zoomkat 5-1-12
//simple button GET for servo and pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  //enable serial data print
  Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println(F("<HTML>"));
          client.println(F("<HEAD>"));
          client.println(F("<TITLE>Arduino GET test page</TITLE>"));
          client.println(F("</HEAD>"));
          client.println(F("<BODY>"));
          client.println(F("<H1>Zoomkat's simple Arduino button</H1>"));
          client.println(F("<a href='/?on'>ON</a>"));
          client.println(F("<a href='/?off'>OFF</a>"));
          client.println(F("</BODY>"));
          client.println(F("</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            myservo.write(40);
            digitalWrite(5, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            myservo.write(140);
            digitalWrite(5, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
but strstr() requires a char * (it's a pointer) not uint8_t.
Ah. I didn't notice that it wasn't a direct replacement for indexOf...
   char mysubstring[80];
   char netresponse[80] = ...;
   char *substringStart = strstr(netresponse, "&"); // find start
   strcpy(mysubstring, substringStart);  // copy all stuff past start delimiter.
   substringStart = strstr(mysubstring, "time");  // find end
   *substringStart = 0;  // terminate the substring.
(Note that the storage reserved for the substring now needs to be larger, since it will temporarily hold the whole "second half" of the original string.)
The regular expression library to which I alluded further up was designed so that the captures did not require any extra memory. Not, at least, unless you need to copy them somewhere.
However in a simple case like this, a state machine should be all that is required.
