This is all new to me, so Im spending alot of time learning basics at the moment
I have four relays connected and an 0,96" oled display and I wish to have some sort of an indication for each relay if they are active or not. At the moment I have a number "1" for Relay1 when its active and number "0" when its not. But instead of updating the display is showing both numbers at the same time, as if it dosnt update with the relay.
Not all that simple to explain, but here is my code so far:
#include <Sodaq_DS3231.h>
#include <dht.h>
#include "U8glib.h"
#include <Button.h>
U8GLIB_SSD1306_128X64 oled(U8G_I2C_OPT_NONE);
Sodaq_DS3231 RTC;
byte hours;
byte minutes;
byte seconds;
dht DHT;
#define DHT11_PIN 4
#define RELAY_ON 1
#define RELAY_OFF 0
#define Button_ON 1
#define Button_OFF 0
#define Relay_1 5
#define Relay_2 6
#define Relay_3 9
#define Relay_4 10
Button Purge(2);
Purge.begin();
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
digitalWrite(Relay_3, RELAY_OFF);
digitalWrite(Relay_4, RELAY_OFF);
//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
pinMode(Relay_3, OUTPUT);
pinMode(Relay_4, OUTPUT);
delay(4000); //Check that all relays are inactive at Reset
updateTime();
oled.firstPage();
DateTime now = rtc.now();
// Kanal #1
if (now.minute() == 00) {
digitalWrite(Relay_1, RELAY_ON);
if (now.minute() == 01) {
// Kanal #2
if (now.minute() == 15) {
digitalWrite(Relay_2, RELAY_ON);
if (now.minute() == 16) {
// Kanal #3
if (now.minute() == 30) {
digitalWrite(Relay_3, RELAY_ON);
if (now.minute() == 31) {
// Kanal #4
if (now.minute() == 45) {
digitalWrite(Relay_4, RELAY_ON);
if (now.minute() == 46) {
// Purga ut vattnet i 15 sekunder
else if(Purge.pressed()) {
delay(15000);
do {
draw();
while (oled.nextPage());
delay(50);
void updateTime() {
hours = now.hour();
minutes = now.minute();
seconds = now.second();
void draw(void) {
oled.setFont(u8g_font_fub17);
char timeString[10];
sprintf(timeString, "%02u:%02u:%02u", hours, minutes, seconds);
oled.setPrintPos(20, 32);
oled.print(timeString);
oled.setFont(u8g_font_fixed_v0);
int chk = DHT.read11(DHT11_PIN);
oled.setPrintPos(0, 52);
oled.print("Temp: ");
oled.print(DHT.temperature);
oled.print(" c");
oled.setPrintPos(0, 64);
oled.print("Humid: ");
oled.print(DHT.humidity);
oled.print("%");
delay(130);
oled.drawLine(0, 10, 128, 10);
oled.drawLine(0, 37, 128, 37);
oled.drawLine(86, 37, 86, 64);
oled.setPrintPos(95, 58);
oled.print("08:00");
//Kanal #1 GUI
if (Relay_1, RELAY_ON) {
oled.setPrintPos(0, 8);
oled.print("1");
if (Relay_1, RELAY_OFF); {
oled.print("0");
//Kanal #2 GUI
if (Relay_2, RELAY_ON) {
oled.setPrintPos(42, 8);
oled.print("2");
if (Relay_2, RELAY_OFF); {
oled.print("0");
//Kanal #3 GUI
if (Relay_3, RELAY_ON) {
oled.setPrintPos(86, 8);
oled.print("3");
if (Relay_3, RELAY_OFF); {
oled.print("0");
//Kanal #4 GUI
if (Relay_4, RELAY_ON) {
oled.setPrintPos(122, 8);
oled.print("4");
if (Relay_4, RELAY_OFF); {
oled.print("0");
I do understand, that this is for sure not going to happen my way. But how would you do this in the best and simplest way so that there is some sort of a indication for the 4 relays on the oled?
