Hi there, i want to light one of three LEDs in my led-strip, while keeping the others turned off. Right now i can only get the same color for each of the LEDs.
The ledstrip is a worldsemi RGB led strip with GND, DIN and 12v.
I am using the library fastLed for arduino and i am running the code from their own example, as seen below.
As said, i CAN light all of the LEDs in one color, however I CANNOT light them individually.
Thanks!
// Use if you want to force the software SPI subsystem to be used for some reason (generally, you don't)
// #define FASTLED_FORCE_SOFTWARE_SPI
// Use if you want to force non-accelerated pin access (hint: you really don't, it breaks lots of things)
// #define FASTLED_FORCE_SOFTWARE_PINS
#include "FastLED.h"
// Move a white dot along the strip of leds. This program simply shows how to configure the leds,
// and then how to turn a single pixel white and then off, moving down the line of pixels.
// How many leds are in the strip?
#define NUM_LEDS 3
// Data pin that led data will be written out over
#define DATA_PIN 6
// Clock pin only needed for SPI based chipsets when not using hardware SPI
//#define CLOCK_PIN 8
// This is an array of leds. One item for each led in your strip.
CRGB leds[NUM_LEDS];
// sanity check delay - allows reprogramming if accidently blowing power w/leds
delay(2000);
// FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
// your leds.
leds[0] = CRGB::Red;
leds[1] = CRGB::Black;
leds[2] = CRGB::Black;
FastLED.show();
