induction motor speed variator
I need to vary the speed of a 230v induction motor
Nordin:
If you are sure it's an induction motor, then you already know it is designed for the frequency on the name plate. Otherwise be prepared for failure.
Paul
honestly I'm not so sure because I saw that he had the condenser on the neuto and I thought it was induction. this engine had its own centarina that regulates the speed but it is broken and I wanted to do one myself
Also here
Nordin:
The small motor current and small capacitor indicate a "split phase" motor. Google will let you learn how that type of motor works.
Paul
The motor appears to be a fan-drive motor. If so, and you want to control the amount of air flowing, you might have more success by building a small servo-motor operated damper flap to restrict the air stream.
Can we see inside the broken controller?
As this is a fan motor the speed control will be a narrow range and may be accomplished in various different ways which is why the controller is key.
