Inductive PNP sensor
Hi.
Link to datasheet: https://www.turck.de/datasheet/_en/edb_1634879_gbr_en.pdf
I didnt work with this PNP senzor but i guess that wiring is standard based.
It has 4 pin connector but only 3 wires are connected. So, something like this should do the trick (2x 10K, gnd together ) ?
For PNP output you'll get 12V on the output, bringing that down to just under 5V requires a different ratio. 15k + 10k would do better, giving you 4.8V on the pin.
