So I want to use the lj12a3-4-z/bx inductive proximity sensor. It has 3 wires: Brown: V+, Blue: GND and Black: signal
Its operating voltage is 6VDC - 36VDC and thus I use a battery of 9VDC to power the sensor. But then I have no idea how to hook up the signal wire from the sensor to the arduino uno.
Is it digital or analog? To which pin should I connect it to? Or should I used the arduino itself to power the sensor instead of using a battery?
I've done some searching on the arduino forms, but so far I only found info about a two wire sensor.
