I want to use a coil to sense a rapid current pulse passing through a wire nearby. I hooked up the coil to oscilloscope and the following is what I see.
The amplitude can be as high as 60 volts and the period is about 25ns. The question is how can I make the signal suitable for Arduino.
I think I need to make the maximum voltage ~5 volts and lower and make a output pulse longer enough so I can pick it up with polling or with an interrupt. Can anyone recommend a circuit?
Thanks.
Richard,
I only need to detect the pulse, the occurrence of the pulse. I don't need the other information.
There probably isn't much current. I think what I saw was the induced current bouncing around in the parasitic RLC circuit of the coil and the oscilloscope probe.
I didn't try LED or opto-isolator. The voltage isn't correct and perhaps the energy isn't sufficient.
Thanks.
For starters I would use four diodes in a full wave rectifier with -ve connected to ground. Then from the +ve end through a series diode and series resistor (100R) to the analogue input of the arduino. In parallel to the input I would put a 1uF capacitor and a 10K resistor across that to act as a peak detector. Finally you need catcher diode (any small signal diode) from the analogue (anode) input to the +5V supply (cathode).
Mike,
Were you describing a circuit like this?
What's the purpose of the diode after the full wave rectifier? 100R means 100 ohms?
Thanks.
