Hello guys
I'm Using Arduino Protenta Machine Control with 24 v power supply and 24 v digital input.
I wanna know wich sensors can I use for the tempreture outside (it has to be waterproof) ?
thanks
Hello guys
thanks
https://www.google.com/search?q=waterproof+arduino+temperature+sensor
But, depending on the length from the Arduino base, you may need to expand your search into 'wireless' but that must include consideration on power: batteries, solar, AC availability, and so forth.
https://www.google.com/search?q=wireless+battery+waterproof+arduino+temperature+sensor
thanks for the replay
but I can't use the wierles sensor
all what I need is a waterproof sensor or any good way to make the Arduino Sensors like SHT31 waterproof.
One must be cautious with homemade waterproofing using consumer products like silicone caulk or 2-part epoxy:
The bead thermistors are usually ceramic devices and often conformal coated anyway: with these devices, the wire leads just need to be waterproofed as the "bead" is waterproofed.
I once had a salvaged thermistor that was in a sealed glass tube. Wires were sealed at one end of the tube. The OP can do the same. Response to changing temperature was slowed, of course.
No need if you use one of these:
