inet.httpGET - submitting sensor data in char* path
Now i got one more problem with inet.httpGET char*path below. the following syntax is working
inet.httpGET("api.pushingbox.com", 80, "/pushingbox?devid=v****8&Temperature=30.65", msg, 0);
But I need to put a variable in place of 30.65 in a void loop() as in the following code
float Temp;
void loop() { Temp = analogRead(tempPin); inet.httpGET("api.pushingbox.com", 80, "/pushingbox?devid=v***8&Temperature=?Temp?*", msg, 0); delay(1000); }
What should i place instead of ?Temp? in above line?
Thank you --Santhosh
