Inexpensive mid-infrared source + detector
Hello,
I’m looking for a low power source (LED, laser or other, it’s not important) in the mid infrared (around 2100nm - 2.1um) and an appropriate detector for it, I need it to build an infrared “colorimeter” which I hope it will work for a project I want to start working on. An IR spectrophotometer would be perfect but you know how much they cost…
Every component I found is above 100 euro/dollars which is too much considering that I don’t know if it will even work for my application, but maybe someone can suggest me an inexpensive alternative.
Many thanks
That is not easy. You can not use silicon to make emitters and detectors that operate at that frequency.
Sounds like a bargain to me given the specification.
I built a spectrometer from instructions and software online for detecting UV and apparently suitable for IR.
No idea if you are chasing the same thing or not.
One of a few available here.......
Well no he is not. The wavelength of what a silicon based web cam chip can detect is a lot smaller than he OP wants to measure. He wants 2100nm where as a webcam works at around 840nm.
Thermal camera sensor ($40) might be useable for that frequency.
Yes good catch. :slight_smile:
Still leaves the problem of the emitter though.
There is no need for a camera, a single IR temperature sensor (pyrometer/termophile) would be ok, the problem is that they works from around 4 um above.
So no, they can't be used.
Are you trying to measure measure absorbance at 2 uM wavelength? Tell us more about this project.
