I'm in the planning stages of a costume with a large head which I want to have hands-free control of. The plan is to use servos of some kind along with some combination of accelerometers, gyros, flex sensors, rotary encoders or whatever to match the motion of the head with that of my own.
My best guess is that the head will weigh 3-4 pounds, will be approximately 24 inches long, with the pivot point 6" in from the back of the skull. It will taper to the snout but not by much so the mass distribution can be approximated as a box 24x12x12 in size.
I don't know if adding a spring or additional weight to somehow counterbalance it would help any with the torque.
Anyway, what I'm wondering is if there are servos that aren't thousands of dollars which can lift this kind of weight? There won't be room for significant leverage, but a 4" lever may be possible. A servo doesn't rotate very far though, so the lever idea might not work out since the head wouldn't rotate very far.
Stepper motors I suppose are also a possibility. I don't have experience using them but I don't have to build a circuit from scratch to control them either. I'm not sure how one would attach something like a head or a level to a stepper motor shaft though. What would one use?
Any ideas for servos / motors or even a way to control this with only head movements would be helpful.
