Hi Everyone,
Let me explain my program first so the code makes sense, not that its that hard to understand at all. Basically I want to read in a byte, or some bytes from the serial input of my UNO. That serial data will then trigger a RGB LED to either light up with a single color, or cycle through a pattern of colors. If the LED is cycling through the pattern, I want to give the user the ability to “exit” the pattern if new serial data arrives and execute that new request. Reason being is the color cycling may take like 3 minutes to complete (when I tweek that code). So I dont want serial data to sit in the buffer and the user to have to wait until the color cycling is over before their “new” request is acted upon.
Here is a simple proof of concept I came up with to test out this theory which will then be incorporated into a larger program later. Now when I execute this, if I enter a value of 1, it does what it should which is paint the ring RED. But If I enter the 9, it does nothing but the serial println prints out. It has to do with the If Serial available line, because if I comment that out, the ring lights up. Any thoughts??? I really just want the code to “interupt” when serial data arrives, read it in, and start the whole loop over again, sounds easy LOL thanks in advance!
Note: This uses a Adafruit NeoPixel ring, which is the reason for the NeoPixel library naturally
#include <avr/power.h>
#define PIN 6 // connected to NeoPixel ring
/* Parameter 1 = number of pixels in strip
Parameter 2 = Arduino pin number (most are valid)
Parameter 3 = pixel type flags, add together as needed:
NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
/* IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
and minimize distance between Arduino and first pixel. Avoid connecting
on a live circuit...if you must, connect GND first.
//**********SETUP FUNCTION***************************************
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// *******************LOOP FUNCTION********************************
if (Serial.available() > 0) { // If serial data is present
start: // GOTO label
int inByte = Serial.read(); // read it in (will only be one byte for this POC)
if(inByte=='1') {
Serial.println("Case statement 1 Colorwipe Red executed");
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, 255,0,0);
strip.show();
delay(50);
} // end inByte 1 IF statement
if(inByte=='9') {
Serial.println("Case statement 9 RainbowCycle executed");
for(uint16_t j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(uint16_t i=0; i< strip.numPixels(); i++) {
if(Serial.peek() !=-1) {goto start;} // if serial data is NOT present then continue else goto
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
} // end i loop
strip.show();
delay(20);
} // end j loop
} // end inByte 9 IF statement
} // end Serial IF statement
} // End LOOP
// **********************UINT32 FUNCTION********************************
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
