welchen „include“ Befehl muss ich für das Motorshield benutzen?
Danke
Danke
If this Infineon product is what you mean then it is not a shield, it is just an integrated circuit.
The datasheet says it is a "half-bridge" so I assume it would only be capable of motor control in a single direction.
And please note that you have asked your question in the English language section of the Forum. There is also a German section if you would prefer to use it.
...R
Thank you. I want to control a 250 Watt DC Motor with my Motor shield and an effect hall sensor.
I have no idea how to begin because it is my first time using an arduino board. could someone drop me a beginning code which i could try on an modify by myself? That would be very helpful...
thanks
Please post a link to the datasheet for your motor.
What will be the voltage of the motor power supply?
You have not said whether I have identified the correct part?
You have not said if you want to control the motor in two directions?
It would be a big help if you describe the project you wish to create.
...R
