Infinite Trouble using Uno to program Attiny85
So i keep getting this error message (seen below) and google does not supply sufficiant help for this one ;D. So Ive gotten this code working via the arduino but when i choose to upload it with the Uno no matter what i get this error. I cant even start the process becuase of this block.
Heres the error message (at the bottom of the code)
#include "SPI.h"
#include "WS2801.h"
const int buttonPin = 4;
int dataPin = 2;
int clockPin = 3;
int oldButtonVal = 0;
int nPatterns = 4;
int lightPattern = 1;
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
// Don't forget to connect the ground wire to Arduino ground,
// and the +5V wire to a +5V supply
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
WS2801 strip = WS2801(2, dataPin, clockPin);
// Optional: leave off pin numbers to use hardware SPI
// (pinout is then specific to each board and can't be changed)
//WS2801 strip = WS2801(25);
    strip.begin();
    strip.show();                // initialize all pixels to 'off'
// initialize the BUTTON pin as an input
    pinMode(buttonPin, INPUT);
    digitalWrite(buttonPin, HIGH);  // button pin is HIGH, so it drops to 0 if pressed
  // initialize the pushbutton pin as an input:
  // Update LED contents, to start they are all 'off'
  // Some example procedures showing how to display to the pixels
   // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
   int buttonVal = digitalRead(buttonPin);
  if (buttonVal == LOW && oldButtonVal == HIGH) {// button has just been pressed
    lightPattern = lightPattern + 1;
  if (lightPattern > nPatterns) lightPattern = 1;
  oldButtonVal = buttonVal;
  switch(lightPattern) {
    case 1:
      pattern1();
    case 2:
      pattern2();
      case 3:
      pattern3();
    case 4:
      pattern4();
      case 5:
      pattern5();
    case 6:
      pattern6();
      case 7:
      pattern7();
    case 8:
      pattern8();
      case 9:
      pattern9();
    case 10:
      pattern10();
      case 11:
      pattern11();
    case 12:
      pattern12();
}void pattern1() {
     strip.setPixelColor(0, LOW);
     strip.setPixelColor(1, LOW);
     strip.show();   // write all the pixels out
  } void pattern2() {
     strip.setPixelColor(0, Color(255,0,255));
     strip.setPixelColor(1, Color(0,0,255));
  }  void pattern3() {
     strip.setPixelColor(0, Color(0,255,255));
     strip.setPixelColor(1, Color(100,0,255));
  }  void pattern4() {
     strip.setPixelColor(0, Color(0,255,0));
     strip.setPixelColor(1, Color(100,255,255));
    } void pattern5() {
  }  void pattern6() {
  }  void pattern7() {
    } void pattern8() {
  }  void pattern9() {
  }  void pattern10() {
    } void pattern11() {
  }  void pattern12() {
void rainbow(uint8_t wait) {
  int i, j;
  for (j=0; j < 256; j++) {     // 3 cycles of all 256 colors in the wheel
    for (i=0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel( (i + j) % 255));
    delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
  int i, j;
  for (j=0; j < 256 * 5; j++) {     // 5 cycles of all 25 colors in the wheel
      // tricky math! we use each pixel as a fraction of the full 96-color wheel
      // (thats the i / strip.numPixels() part)
      // Then add in j which makes the colors go around per pixel
      // the % 96 is to make the wheel cycle around
      strip.setPixelColor(i, Wheel( ((i * 256 / strip.numPixels()) + j) % 256) );
    delay(wait);
// fill the dots one after the other with said color
// good for testing purposes
void colorWipe(uint32_t c, uint8_t wait) {
  int i;
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
/* Helper functions */
// Create a 24 bit color value from R,G,B
uint32_t Color(byte r, byte g, byte b)
  uint32_t c;
  c = r;
  c <<= 8;
  c |= g;
  c <<= 8;
  c |= b;
  return c;
//Input a value 0 to 255 to get a color value.
//The colours are a transition r - g -b - back to r
uint32_t Wheel(byte WheelPos)
  if (WheelPos < 85) {
    return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if (WheelPos < 170) {
    WheelPos -= 85;
    return Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else {
    WheelPos -= 170;
    return Color(0, WheelPos * 3, 255 - WheelPos * 3);
In file included from GOTIT.ino:1:
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h: In static member function 'static byte SPIClass::transfer(byte)':
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:56: error: 'SPDR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:57: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:57: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h: In static member function 'static void SPIClass::attachInterrupt()':
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:63: error: 'SPCR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:63: error: 'SPIE' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h: In static member function 'static void SPIClass::detachInterrupt()':
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:67: error: 'SPCR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:67: error: 'SPIE' was not declared in this scope
[code/]
[code/]
