Influxdb write via Arduino
hello, i am new to this and wanted to write data from my arduino via ESP8266 01 to an influxdb. First i wanted to use tobiasschuerg library, however it seems, that is is not compatible with the ESP01 model i have. I want therefore to use either UDP or HTTP protocols to send the data.
My question would be, how should i set up the influxdb for it to write the data, since my arduino code should look like this:
udp.beginpacket(URL,8086);
udp.write(line);
udp.endPacket();
and i need authorization like username/password/token to write in the influxdb.
How should i configure the influxdb for it to work? or are there other alternatives for arduino to write data in influxdb?
Thanks :slight_smile:
Never used it but is this what your looking for.
