Info regarding chip type 3.95" lcd module for mega2560
Hi ive recently bought this board from here
the output for LCD ID NEW is as follows
Read Special Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
diagnose any controller
reg(0x0000) 00 00	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 04 04 04 04	Manufacturer ID
reg(0x0009) 09 09 09 09 09	Status Register
reg(0x000A) 0A 0A	Get Power Mode
reg(0x000C) 0C 0C	Get Pixel Format
reg(0x0030) 30 30 30 30 30	PTLAR
reg(0x0033) 33 33 33 33 33 33 33	VSCRLDEF
reg(0x0061) 61 61	RDID1 HX8347-G
reg(0x0062) 62 62	RDID2 HX8347-G
reg(0x0063) 63 63	RDID3 HX8347-G
reg(0x0064) 64 64	RDID1 HX8347-A
reg(0x0065) 65 65	RDID2 HX8347-A
reg(0x0066) 66 66	RDID3 HX8347-A
reg(0x0067) 67 67	RDID Himax HX8347-A
reg(0x0070) 70 70	Panel Himax HX8347-A
reg(0x00A1) A1 A1 A1 A1 A1	RD_DDB SSD1963
reg(0x00B0) B0 B0	RGB Interface Signal Control
reg(0x00B3) B3 B3 B3 B3 B3	Frame Memory
reg(0x00B4) B4 B4	Frame Mode
reg(0x00B6) B6 B6 B6 B6 B6	Display Control
reg(0x00B7) B7 B7	Entry Mode Set
reg(0x00BF) BF BF BF BF BF BF	ILI9481, HX8357-B
reg(0x00C0) C0 C0 C0 C0 C0 C0 C0 C0 C0	Panel Control
reg(0x00C1) C1 C1 C1 C1	Display Timing
reg(0x00C5) C5 C5	Frame Rate
reg(0x00C8) C8 C8 C8 C8 C8 C8 C8 C8 C8 C8 C8 C8 C8	GAMMA
reg(0x00CC) CC CC	Panel Control
reg(0x00D0) D0 D0 D0 D0	Power Control
reg(0x00D1) D1 D1 D1 D1	VCOM Control
reg(0x00D2) D2 D2 D2	Power Normal
reg(0x00D3) D3 D3 D3 D3	ILI9341, ILI9488
reg(0x00D4) D4 D4 D4 D4	Novatek
reg(0x00DA) DA DA	RDID1
reg(0x00DB) DB DB	RDID2
reg(0x00DC) DC DC	RDID3
reg(0x00E0) E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0 E0	GAMMA-P
reg(0x00E1) E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1 E1	GAMMA-N
reg(0x00EF) EF EF EF EF EF EF	ILI9327
reg(0x00F2) F2 F2 F2 F2 F2 F2 F2 F2 F2 F2 F2 F2	Adjust Control 2
reg(0x00F6) F6 F6 F6 F6	Interface Control
any help on the driver or the id of this would be appreciated. I just cant seem to get anything but the white screen
This seems to match the board you have. There are downloads for libraries and documentation.
http://www.lcdwiki.com/3.95inch_Arduino_Display-Mega2560
Thanks for that ... Yes ive been there installed it into the ide. And just the white screen .Ive tried the adafruit version also MCUFRIEND... compiles uploads yet white screen i also have another screen with a 8230 chip in it and that worked almost straight away with the MCUFRIEND_kbv library (on an uno).... I didnt think the bigger screen on a mega would be causing so much trouble for me maybe i was spoilt with the first one
But this board uses an ILI9488 chip.
Thats what i mean was easy as pie to get the 8230 chip one to work but the ILI9488 has me pulling my hair out.
