Infrared inconsistency
hey I have a weird problem, my cieling fans remote stopped working but thankfully I captured the infrared signal with my flipper zero before, now I am trying to make a new remote, I have the signals but every time I send them the results are diffrent, when I capture them it's a diffrent signal every time (also the LED's always seem to be weak) also it unsurprisingly does not work on the fan. I would appreciate help.
Using correct tags, post your code.
Does it work if you send the signal from F zero?
no, I tried it every time, the signal is totaly diffrent every time
what are the correct tags for this topic?
According to who? I don't expect your fan gives that information to you...
Neither I expect that F zero is sending different code every time.
So explain what is your setup at the moment.
How are you sending?
What are you sending?
How are you receiving?
What are you receiving?
What do expect to receive?
How are you capturing?
What LED?
Fan is not part of the IR path.
my flipper zero it a cool tool that has infrared capability, I record the signal and then open the file, it's diffrent every time, and I also try to copy from the led and then transmit from the flipper, and it donsn't work
Read the user manual.
for the flipper?
Hi, @zorry
Welcome to the forum.
With what controller?
What IR LED are you using/
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
hi! yes heres a pictue of my circuit
hope it uploades it right, it's the simplest it can be, an arduino uno, an ir LED and a ressistor.
no matter what I transmit it always appears o give a diffrent signal, thanks.
Where? How it appears?
well, I recorded the signal on my flipper zero and then opened the file and it was always diffrent.
They are always different. It's a question of difference....
Please post your code.
