Infrared interruption in an infinite loop
hello,
I want to make an infrared remote control meter.
with an arduino uno v3, a display, an infrared receiver and remote control
for the momentwhen I press button 1 the counter starts
but when I press button 2 the counter does not stop
When I press button 3 the counter does not reset to Zero
How could I arrange the infinite loop to handle button interrupts 2 and 3?
here is my code:
#include <TM1637Display.h>
#include <IRremote.h>
#define CLK 2
#define DIO 3
TM1637Display display(CLK, DIO);
int etatBouton,cp,run;
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
run=1;
cp=0;
	display.setBrightness(0x0f);
	irrecv.enableIRIn();
	irrecv.blink13(true);
void loop(){
if (irrecv.decode(&results)){
	if (results.value == 0XFF38C7) {            // button1	start counter
		while(run==1) {
			cp++;
			display.showNumberDec(cp);
			if (results.value == 0XFFB04F){	 //  button2  stop counter
				run=0;
	if (results.value == 0XFF6897) {            //button3 reset counter
	cp=0;
//FF38C7    button1
//FFB04F    button2
//FF6897    button3
Thanks for your help
In the while loop you are never performing another irrecv.decode(&results) and therefore results.value never gets updated with the button2 code. Also you need to do an irrecv.resume() after a successful decode to get the next value.
What version of the library are you using ?
Never use delay ( ) or blocking while( )
Well, unless you know why you shouldn’t :wink:
@LarryD makes a good point. I forgot about the update. 2.x vs 3.x
https://github.com/Arduino-IRremote/Arduino-IRremote#converting-your-2x-program-to-the-3x-version
Get rid of the infinite loop. Use a millis() timer to increment and display the counter. That leaves only a little to do for each button.
  static unsigned long lastCountTime = 0;
  unsigned long currentTime = millis();
  if (currentTime - lastCountTime >= 1000)
    lastCountTime += 1000;
    if (run == 1)
      cp++;
    if (results.value == 0XFF38C7)        // button1  start counter
      if (run == 0)
        run = 1;
        lastCountTime = currentTime;
    else if (results.value == 0XFFB04F)  //  button2  stop counter
      run = 0;
    else if (results.value == 0XFF6897)  // button3 reset counter
      cp = 0;
    irrecv.resume();  // Edit: Thanks @ToddL1962 for the reminder.
//FF38C7    button1
//FFB04F    button2
//FF6897    button3
...and don't forget about the irrecv.resume() call;
thank you it works great
