Infrared remote controls LED Multicolour is all ffffffff
Hello
I have a question and hope you can help me.
I would like to read out infrared remote controls, that also works quite well with TV remote control, only the LED remote controls multicolor that I want to read, I only get ffffffff, I found this forum entry, but it didn't get me anywhere.
IRremote: Every second value is FFFFFFFF - Using Arduino / Programming Questions - Arduino Forum
I have the code of groundFungus with
irrecv.resume();
Serial.println("...ffffffff");
The result is:
-> ...ffffffff
The questions now are:
  1. Can I not read this LED remote control multicolor at all?
  2. Do I need a different library?
Ich verwende die IDE 2.2.1 mit einem ESP32 und einem VS18388 IR Sensor und dem Code den auch groundFungus verwendet hat plus meine Ă„nderung.
Why did I do this?
I would like to use the LED remote controls multicolor that I have available for the LED control in WLED, at the moment the correct colors are not reproduced.
If anyone has another idea how I can solve the problem with the LED remote controls multicolor in WLED, I would also be very interested!
thanks.
BR
Rene
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Ir-remote controls use different carrier-frequencies
some 36 kHz, some 38 kHz, some 40 kHz.
The datasheet of the VS1838 mentions 38 kHz
If your LED remote uses a different carrier-frequency it does not work.
You might be able to analyse this with a photodiode or a photo-transistor
though I don't have a schematic at hand what other components are required.
Another option is to by IR-receivers with different carrier-frequencies
best regards Stefan
Hello Stefan,
Thanks for your reply.
Carrier frequencies is probably the key word here.
I thought infrared is always the same and only encoded by the frequency, but it doesn't tell anyone... :sweat_smile:
I have now ordered a TSOP38238, which according to WLED should work with the LED remote controls multicolor.
I'll let you know if I get stuck or if I've solved it.
best regards René
