Im controlling 433mhz sockets with an IR remote and 433mhz transmitter connected to arduino. I would like a couple of the sockets to turn off after a set amount of time. So I press the button set amount of time passes and they auto turn off. I
m trying to do this at the min with button 5 with is socket number 5. Just trying 5 sec delay so it should turn off after 5 secs but it just doesn't turn off. When I say <= autoOffTime off it turns off straight away if I put >= it wont turn off. Here is the code I have at the min. Some buttons turn off more than one socket but that is working fine.
#include <RCSwitch.h>
#include <IRremote.h>
const int mainLight = 4;
const int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long timer = 0;
RCSwitch mySwitch = RCSwitch();
struct RCStructure
boolean state;
unsigned long codeID;
unsigned long onCode;
unsigned long offCode;
unsigned int codeLength;
char letter;
boolean autoOff;
const unsigned long autoOffTime;
unsigned long onCode2;
unsigned long offCode2;
unsigned long onCode3;
unsigned long offCode3;
RCStructure remoteKey[] = {
{false, 0xC101E57Bul, 1398211ul, 1398220ul, 24, '0', false, 0ul, 1398531ul, 1398540ul}, //when you press the 0 button
{false, 0x9716BE3Ful, 4543795ul, 4543804ul, 24, '1', false, 0ul}, //when you press the 1 button
{false, 0x3D9AE3F7ul, 4543939ul, 4543948ul, 24, '2', false, 0ul}, //when you press the 2 button
{false, 0x6182021Bul, 4544259ul, 4544268ul, 24, '3', false, 0ul}, //when you press the 3 button
{false, 0x8C22657Bul, 4545795ul, 4545804ul, 24, '4', false, 0ul}, //when you press the 4 button
{false, 0x488F3CBBul, 4551939ul, 4551948ul, 24, '5', true, 5000ul}, //when you press the 5 button
{false, 0x449E79Ful, 349491ul, 349500ul, 24, '6', false, 0ul}, //when you press the 6 button
//{false, 0x32C6FDF7ul, 349635ul, 349644ul, 24, '7', false, 0ul}, //when you press the 7 button
{false, 0x1BC0157Bul, 349955ul, 349964ul, 24, '8', false, 0ul, 351491ul, 351500ul, 357635ul, 357644ul}, //when you press the 8 button
{false, 0x3EC3FC1Bul, 1398067ul, 1398076ul, 24, '9', false, 0ul}, //when you press the 9 button
{false, 0x97483BFBul, 1400067ul, 1400076ul, 24, 'U', false, 0ul}, //When you press the 100+ button
{false, 0xF0C41643ul, 1406211ul, 1406220ul, 24, 'D', false, 0ul}, //When you push the 200+ button
const byte remoteKeySize = sizeof(remoteKey) / sizeof(remoteKey[0]);
Serial.begin(9600); //starts serial communication
irrecv.enableIRIn(); // Start the receiver
pinMode(mainLight, OUTPUT);
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(10);
mySwitch.setPulseLength(190);
// check the remote control
if (irrecv.decode(&results)) {
for (byte i = 0; i < remoteKeySize; i++) { // check which key is pressed
if (results.value == remoteKey[i].codeID) {
// we found the key, do what's needed
Serial.println(remoteKey[i].letter); // debug only, print the letter on the key
if (remoteKey[i].state) {
remoteKey[i].state = false;
mySwitch.send(remoteKey[i].offCode, remoteKey[i].codeLength);
mySwitch.send(remoteKey[i].offCode2, remoteKey[i].codeLength);
mySwitch.send(remoteKey[i].offCode3, remoteKey[i].codeLength);
else {
remoteKey[i].state = true;
mySwitch.send(remoteKey[i].onCode, remoteKey[i].codeLength);
mySwitch.send(remoteKey[i].onCode2, remoteKey[i].codeLength);
mySwitch.send(remoteKey[i].onCode3, remoteKey[i].codeLength);
} // for each key
irrecv.resume(); // Receive the next value
// check auto off features
unsigned long AUTO_OFF_DELAY = millis();
if (remoteKey[i].state && remoteKey[i].autoOff && AUTO_OFF_DELAY - timer >= remoteKey[i].autoOffTime) {
timer = AUTO_OFF_DELAY;
//switch case to use the selected remote control button
switch (results.value){
case 0xFF02FD: //When you press the OK Button
digitalWrite(mainLight, HIGH);
digitalWrite(mainLight, LOW);
Thanks
