Infrared Speed Measurement
DogWatch:
My QRE1113 is an analog type
Please post a link to the datasheet for the exact device you have.
I used my QRE1113 devices as digital devices with the Sparkfun "analog" wiring diagram. How close is your senor to the rotating part - it should be about 1 mm IIIRC.
...R
Hello all,
first, thanks to all of you for the quick and detailed help. Today I was able to check the function of the QRE1113 and the interrupt-logic using the code-guidance from Robin2. I used a mill with speed rated up to 24.000 rpm. I used the Sparkfunk QRE1113 breakout on a black (matt) painted mill tool (50% of the shaft was painted the other 50% was unpainted steel). Using the adapted interrupt code from Ronin2 (Thanks!) I was able to measure the shaft speed right away up to 23.000 rpm. Awesome!
I finally connected the QRE1113 (analog version) output to the digital pin 2 (INT0). Important is to use black matt paint in order have a good High/Low signal at the QRE1113 output. The distance between sensor and shaft should be between 1 to 2mm. The QRE1113 doc is talking about 3mm distance for best performance which ist not the case obviously.
Anyway, I'm happy to have a good and simple way to measure the rotational speed in my project.
Thank you all very much.
Regards,
Joerg
//##################################### HEADER #############################################################
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width,  in pixels
#define SCREEN_HEIGHT 32                                         // OLED display height, in pixels
// declare an SSD1306 display object connected to I2C
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
//int QRE1113_Pin = A0;
const byte interruptPin = 2;                                 // QRE1113 output connected to use "INTERRUPT.0"
unsigned long revMicros;
unsigned long prevRevMicros;
unsigned long revDuration;                                   // calculated duration between two IR pulses by turning shaft
//unsigned long revCount;                                    // to count number of revolutions
double shaftSpeed;
// variables for the ISR (Interrupt Service Routine)
volatile unsigned long isrMicros;
volatile unsigned long isrCount;
volatile bool newIsrMicros = false;
int waitTime = 200;
unsigned long previousTime;
//##################################### SETUP ##############################################################
  pinMode(interruptPin, INPUT_PULLUP);
  //pinMode(A0, INPUT);
  // define interrupt to dectect rising singnal when black (no reflexion) detected by IR sensor
  isrCount = 0;
  attachInterrupt(digitalPinToInterrupt(interruptPin), revDetectorISR, RISING);
  // initialize OLED display with address 0x3C for 128x64
  if (!oled.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    while (true);
  oled.display();                                            // start screen on oled
  oled.clearDisplay();
  oled.setTextSize(3);
  oled.setTextColor(WHITE);
  oled.setCursor(20, 8);
  oled.println(F("READY"));
  oled.display();
  previousTime = millis();
//##################################### LOOP ###############################################################
  getIsrData();
  if(millis() - previousTime > waitTime) {
    shaftSpeed = 1 / (float)revDuration * 60000000.0;       // shaft speed converted from microsecond per turn to rpm
    if (shaftSpeed < 1000000.0 && shaftSpeed > 100.0) {     // no data to oled screen outside speed limits
      writeToOLED(String(shaftSpeed,0));
    }else{
      writeToOLED("0");
    //showDataToMonitor();
//##################################### FUNCTIONS  #########################################################
void getIsrData() {
    if (newIsrMicros == true) {
        prevRevMicros = revMicros;                           // save the previous value
        noInterrupts();
            revMicros = isrMicros;
            //revCount = isrCount;
        interrupts();
        revDuration = revMicros - prevRevMicros;
// called within interrupt handler (see setup())
void revDetectorISR() {
    isrMicros = micros();
    //isrCount ++;
    newIsrMicros = true;
void writeToOLED(String val) {
  oled.clearDisplay();                                        // clear display
  oled.setTextSize(3.5);
  oled.setTextColor(SSD1306_WHITE);
  oled.setCursor(20, 0);
  oled.println(val);
  oled.setTextSize(1);
  //oled.setTextColor(SSD1306_WHITE);
  oled.setCursor(100, 25);
  oled.print(F("rpm"));
  oled.display();
void showDataToMonitor() {
    Serial.println("===============");
    Serial.print("  Rev Duration ");
    Serial.print(revDuration);
    Serial.print("  ShaftSpeed ");
    Serial.print(String(shaftSpeed,0));
DogWatch:
Hello all,
Regards,
Joerg
Nice You got up and running. Have You seen the Karma word below Robins title, in the replies from Robin2 and used it?
Railroader:
DogWatch:
now I have, thanks,
