Infrared with MobalTools
Would it be possible to use Infrared input as buttons (in Mobatools) , and can you suggest how this would be done. Many thanks in advance.
I am using MobaTools to control my stepper motor.
What do you mean by infrared input? Are you using a remote? or something else? Link to datasheet of what your are using?
sorry yes it is a remote.
The IRremote.h and MobaTools.h should work together. But on a 386P there is only one 16-Bit Timer (Timer1) which is used by MobaTools. As far as I rememer, IRremote uses this also by default, but can be configured to use Timer 2 instead.
The MoToButtons class of MobaTools cannot use the buttons of a Infrared remote.
thank you.
