I’ve written a fairly big library which deals with potentiometers, buttons, LEDs, MIDI etc. Now, there is a part of that library which deals directly with hardware. I’ve managed to “separate” that part from library and I’ve put the hardware control functions within my main.cpp (I’m not using any Arduino libs). Here’s how it works:
This is a function which switches columns in a matrix (in my library):
void OpenDeck::nextColumn() {
sendLEDrowsOffCallback();
if (column == _numberOfColumns) column = 0;
sendColumnSwitchCallback(column);
//increment column
column++;
So, before switching to another column, it first turns off all LED rows off, and then activates next column. So, where are those functions? Within my main.cpp. I’ve used callbacks to handle this:
openDeck.setHandleColumnSwitch(activateColumn);
openDeck.setHandleLEDrowsOff(ledRowsOff);
//switch to next matrix column
void activateColumn(uint8_t column) {
//column switching is controlled by 74HC238 decoder
PORTC &= 0b11000111;
PORTC |= (0b11000111 | (column << 3));
//control select pins on mux
void setMuxOutput(uint8_t muxInput) {
PORTC &= 0b11111000;
PORTC |= muxInput;
There are way more functions dealing with hardware, but this should be enough for an example. So, while this works, I find it be a bit tedious: I have to set callback handler, implement it, and also write a chunk of code within my library to make that stuff work. Is there a better way for achieving this? I remember when we coded in Java on college couple of years ago, I don’t remember how was it called, but you could define a function in your library with a certain keyword, and any time you made an object in your main program, you had to implement that function. Is something like that possible in AVR C?
