I've written a couple of my own libraries without too many problems, but I've moved onto a new project involving LCD displays and am having problems.
What I want to do is produce a library that contains all the existing functions of LiquidCrystal.h plus a few of my own, for the moment I'd just like to add a couple of extra functions, one to prefix any number with the appropriate positive or negative sign, and one to right-justify a number.
Here's what I've come-up with so far.
LiquidCrystalFuncs.h......
#ifndef LiquidCrystalFuncs_h
#define LiquidCrystalFuncs_h
extern "C" {
#include <string.h>
#include <stdlib.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "LiquidCrystalFuncs.h" // header for this library
#include <LiquidCrystal.h> // Library for controlling a LCD display.
class LiquidCrystalFuncs
public:
//LiquidCrystalFuncs(); // Constructor
LiquidCrystalFuncs(uint8_t rs,
uint8_t enable,
uint8_t d0,
uint8_t d1,
uint8_t d2,
uint8_t d3);
void begin(void); // Setup object
void setCursor(uint8_t, uint8_t);
void print(int x);
void printS(int x); // Print a number with an appropriate sign.
void printR(int x); // Print a right-justified number.
private:
// Member variables
LiquidCrystal _lcd; // lcd
// Private functions
#endif
LiquidCrystalFuncs.cpp.....
extern "C" {
#include <string.h>
#include <stdlib.h>
#else
#endif
#include <LiquidCrystal.h> // Library for controling a LCD display.
Constructor
LiquidCrystalFuncs::LiquidCrystalFuncs(uint8_t rs, uint8_t enable, uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3)
_lcd.LiquidCrystal(rs, enable, d0, d1, d2, d3);
Do stuff
void LiquidCrystalFuncs::begin(void)
_lcd.begin(20, 2);
Print
void LiquidCrystalFuncs::print(int x)
_lcd.print(x);
Print (with a +ve or -ve sign)
void LiquidCrystalFuncs::printS(int x)
if (x < 0)
_lcd.print("-");
_lcd.print(x);
_lcd.print("+");
_lcd.print(x);
Print a right justified integer. For the moment, assume that it's going
to be a maximum of fours characters.
void LiquidCrystalFuncs::printR(int x)
if (x < 9)
_lcd.print(" "); // Three spaces
_lcd.print(x);
else if (x < 99)
_lcd.print(" "); // Two spaces
else if (x < 999)
_lcd.print(" "); // One space
Serial.println("ooops!");
_lcd.print(x);
I'm pretty sure it's not rocket science I'm trying to do, but getting syntax right is beyond me. Here are the current errors....
C:\all_apps\arduino-1.0\libraries\LiquidCrystalFuncs\LiquidCrystalFuncs.cpp: In constructor 'LiquidCrystalFuncs::LiquidCrystalFuncs(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
C:\all_apps\arduino-1.0\libraries\LiquidCrystalFuncs\LiquidCrystalFuncs.cpp:29: error: no matching function for call to 'LiquidCrystal::LiquidCrystal()'
C:\all_apps\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:56: note: candidates are: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\all_apps\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:54: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\all_apps\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:52: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\all_apps\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:49: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\all_apps\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:45: note: LiquidCrystal::LiquidCrystal(const LiquidCrystal&)
C:\all_apps\arduino-1.0\libraries\LiquidCrystalFuncs\LiquidCrystalFuncs.cpp:33: error: invalid use of 'class LiquidCrystal'
I suspect this is one of those 'it's simple when you know how problems'
Cheers
