Initial memory load failed when trying to display data from MPU6050 on SSD1306
Hello, I encountered an error while trying to extract data (roll position) from gyro-accelerometor MPU6050, and display it on OLED SSD1306 (128 x 64pix). From the serial monitor it reads:
Initializing I2C devices...
Testing device connections...
MPU6050 connection successful
Send any character to begin DMP programming and demo:
Initializing DMP...
DMP Initialization failed (code 1)
According to a line in setup, DMP initialisation failed code 1 is due to initial memory load failed. My sketch size is 22,572 bytes (of a 32,256 byte maximum).
My sketch is based on MPU6050_DMP6 obtained from Github. The sketch correctly calculated roll position using MPU6050 data before I added Adafruit libraries and other display purposes codes for SSD1306. The code 1 error only appeared after codes for SSD1306 was added. I have tried in a separate sketch to make sure that the functionalities and codes for SSD1306 are correct.
I hope you can understand the problem and help me to solve it :blush:
The libraries for MPU6050 and SSD1306 can be found at:
My sketch is as follows:
#include <Wire.h>
//include SSD1306 libraries
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
MPU6050 mpu;
#define LED_PIN 13
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
//SSD1306 pins
#define OLED_DC 11
#define OLED_CS 12
#define OLED_CLK 10
#define OLED_MOSI 9
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
// ===                      INITIAL SETUP                       ===
      //Initialise ssd13006 display
    display.begin();  // by default, generate the high voltage is generated from the 3.3v line internally
    display.clearDisplay();   // clears the screen and buffer
    display.display();
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (115200 chosen because it is required for Teapot Demo output, but it's
    // really up to you depending on your project)
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // wait for ready
    Serial.println(F("\nSend any character to begin DMP programming and demo: "));
    while (Serial.available() && Serial.read()); // empty buffer
    while (!Serial.available());                 // wait for data
    while (Serial.available() && Serial.read()); // empty buffer again
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
    // make sure it worked (returns 0 if so)
    if (devStatus == 0) {
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    // configure LED for output
    pinMode(LED_PIN, OUTPUT);
// ===                    MAIN PROGRAM LOOP                     ===
//    Serial.print(F("dmpReady =\t"));
//    Serial.println(dmpReady);
  // if programming failed, don't try to do anything
    if (!dmpReady) return;
//    Serial.print(F("mpuInterrupt =\t"));
//    Serial.println(mpuInterrupt);
    // reset interrupt flag and get INT_STATUS byte
//    Serial.print(F("mpuIntStatus =\t"));
//    Serial.println(mpuIntStatus);
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
//    Serial.print(F("fifoCount =\t"));
//    Serial.println(fifoCount);
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    } else if (mpuIntStatus & 0x02) {
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        // display Euler angles in degrees
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
//            Serial.print("ypr\t");
//            Serial.print(ypr[0] * 180/M_PI);
//            Serial.print("\t");
//            Serial.print(ypr[1] * 180/M_PI);
//            Serial.println(ypr[2] * 180/M_PI);
            float roll = ypr[2] * 180/M_PI;
            ssd1306_display_roll(roll);
            Serial.print(F("Roll =\t"));
            Serial.println(roll);
        // blink LED to indicate activity
        blinkState = !blinkState;
        digitalWrite(LED_PIN, blinkState);
void ssd1306_display_roll(float roll){
  //display roll value
        display.setTextSize(2);
        display.setTextColor(WHITE);
        display.setCursor(0,21);
        display.print("Roll = ");
        display.print(roll);
//        display.println("°");
        display.display();
Which Arduino board are you using ?
Please don't cross-post: Initial memory load failed when trying to display data from MPU6050 on SSD1306 - Programming Questions - Arduino Forum
Sorry - It's Arduino Uno
It could have something to do with memory, but I think it is not.
As far as I can tell, it is a I2C communication problem.
The MPU-6050 uses a higher speed I2C, and adding the OLED did distort the signal.
Do you run the OLED at 5V ? with I2C ?
So the OLED uses a 5V I2C bus ?
The MPU-6050 needs a 3.3V I2C bus.
If you would use a I2C level shifter, and normal I2C speeds for the MPU-6050, I think it will work.
Hi Caltoa, I previously used a battery pack to power the OLED, and MPU6050 running 3.3V on Arduino. After discovering that the OLED is okay to take 5V, I put it to 5V on Arduino.
Regarding I2C level shifter - do you mean installing one (like this 4-channel I2C-safe Bi-directional Logic Level Converter [BSS138] : ID 757 : $3.95 : Adafruit Industries, Unique & fun DIY electronics and kits) between MPU6050 and Arduino?
Yes, or one of these:
The MPU-6050 might be damaged.
Perhaps you can buy a new one.
If you disconnect the display, is the MPU-6050 working ?
If you create a new sketch for the MPU-6050, can you make that work ?
I'll try to get a level shifter and give it a try.
With the original sketch I posted, the error persists even though I disconnected the OLED. However the MPU6050 works fine In a new sketch where i removed the coding parts for OLED. I can read roll value correctly on serial monitor.
Using the new sketch without codes for display, I tried to put the codes back line by line. First I added the display libraries, then defined digital I/O pin numbers for OLED. The error popped up after I call a function to match the pin numbers. The line by line sequence I uncommented the display codes was as follows:
//SSD1306 pins
#define OLED_DC 11
#define OLED_CS 12
#define OLED_CLK 10
#define OLED_MOSI 9
The dmp initialisation failed code 1 error popped up after the last line above was uncommented. The new sketch with parts for OLED commented is as follows:
#include <Wire.h>
////include SSD1306 libraries
//#include <Adafruit_GFX.h>
//#include <Adafruit_SSD1306.h>
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
//SSD1306 pins
//#define OLED_DC 11
//#define OLED_CS 12
//#define OLED_CLK 10
//#define OLED_MOSI 9
//#define OLED_RESET 13
//Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
//      //Initialise ssd13006 display
//    display.begin();  // by default, generate the high voltage is generated from the 3.3v line internally
//    display.clearDisplay();   // clears the screen and buffer
//    display.display();
        Wire.begin();
    #endif
    // NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
    // Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
    // the baud timing being too misaligned with processor ticks. You must use
    // 38400 or slower in these cases, or use some kind of external separate
    // crystal solution for the UART timer.
    mpu.initialize();
    // wait for ready
        dmpReady = true;
        // ERROR!
        mpu.resetFIFO();
So it might be a memory problem after all.... or a software I2C problem.
I guess the GFX library uses a lot of memory. I have not tried that library yet, although I have ordered an SSD1306 OLED from Ebay.
The initialisation of the SSD1306 calls the Wire.begin(), that might conflict with the I2C settings for the MPU6050.
At this moment I don't have the time to check everything.
