Initial setup for mage with WIFI (XC4421)
I purchased this board - Arduino Mega with WIFI (XC4421) from Jaycar.
Jaycar provides a download section with software and manual,
https://www.jaycar.co.nz/mega-with-wi-fi/p/XC4421
After downloading the software I followed the instructions found in the text file of the download.
Uploading code to the Arduino works fine, but I cannot upload code to the ESP8266.
I follow the instructions exactly. In board manager I set the board to generic ESP8266. I switch pins 5,6,7 to ON and all the others to OFF.
When I upload the code to the ESP and press the reset button when it says "uploading" I receive this message.
Arduino: 1.8.12 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 261368 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26920 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1524 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25232 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 291064 bytes (30%) of program storage space. Maximum is 958448 bytes.
Global variables use 28008 bytes (34%) of dynamic memory, leaving 53912 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: ec:fa:bc:2c:76:f1
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0340
Compressed 295216 bytes to 215639...
Writing at 0x00000000... (7 %)Traceback (most recent call last):
File "C:\Users\Parvesh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in
esptool.main(cmdline)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2938, in main
operation_func(esp, args)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2374, in write_flash
esp.flash_defl_block(block, seq, timeout=DEFAULT_TIMEOUT * ratio * 2)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 104, in inner
return func(*args, **kwargs)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 672, in flash_defl_block
self.ESP_FLASH_DEFL_DATA, struct.pack('<IIII', len(data), seq, 0, 0) + data, self.checksum(data), timeout=timeout)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 369, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 347, in command
p = self.read()
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 292, in read
return next(self._slip_reader)
File "C:/Users/Parvesh/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2057, in slip_reader
raise FatalError('Invalid head of packet (0x%s)' % hexify(b))
esptool.FatalError: Invalid head of packet (0x3B)
option enabled in File -> Preferences.
How do I fix this please
Please use the links below to aid you in posting code and error messages.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
