Initial setup not working - inappropriate ioctl for device
I am brand new to the arduino. Please forgive my lack of knowledge and correct language. bought my son a one up 3d printer which we assembled.
iMac OS 10.9.5
When trying to install arduino, plugging into USB port. Green light but no orange light. Nothing popping up on desktop when plugging in. When using Arduino IDE and setting this up, I only have the following port options: /dev/cu.bluetooth-incoming-port , /dev/cu.bluetooth-modem , and /dev/cu.usbmodem411
In "getting started, it states that I need a port of the following type: /dev/tty.usbmodem
When attempting to upload, I get the following error message:
Arduino: 1.6.5 (Mac OS X), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
The bottom of the verbose error is: avrdude: ser_open(): can't open device "/dev/cu.usbmodem411": No such file or directory
ioctl("TIOCMGET"): Inappropriate ioctl for device
Please help. At a total loss.
Go toTOOLS>SERIAL PORT
Then select /dev/cu.usbmodem411
That should work.
