Initialising array in constructor
this is my first post, so apologies if I make some mistakes posting
I have tried googling around, but maybe I found the answer and I didn't understand it, so I am asking you guys!
I have a fairly simple project:
three buttons, one piezo
when pressing one button, the piezo plays some notes
It works when doing in a "procedural" way, but I would like to be able to extend it using OOP, so I created two classes.
The first one is a Player class
It contains the algorithm to play the notes
The second one is a Songs class
Songs
Songs.h
class Songs{
  public:
	Songs(char title[]);
	int melody[];
	int tempo[];
Songs.cpp
Songs::Songs(char title[]){
	if (title == "sm"){
        //this bit here does not work...
        //compiler says: error: assigning to an array from an initializer list
	   melody = {
		NOTE_E7, NOTE_E7, 0, NOTE_E7, 0, NOTE_C7, NOTE_E7, 0, NOTE_G7, 0, 0,  0, NOTE_G6, 0, 0, 0, NOTE_C7, 0, 0, NOTE_G6,
		0, 0, NOTE_E6, 0, 0, NOTE_A6, 0, NOTE_B6, 0, NOTE_AS6, NOTE_A6, 0, NOTE_G6, NOTE_E7, NOTE_G7, NOTE_A7, 0, NOTE_F7, NOTE_G7,
		0, NOTE_E7, 0, NOTE_C7,	NOTE_D7, NOTE_B6, 0, 0,	NOTE_C7, 0, 0, NOTE_G6,	0, 0, NOTE_E6, 0, 0, NOTE_A6, 0, NOTE_B6, 0, NOTE_AS6, NOTE_A6, 0,
		NOTE_G6, NOTE_E7, NOTE_G7, NOTE_A7, 0, NOTE_F7, NOTE_G7, 0, NOTE_E7, 0, NOTE_C7, NOTE_D7, NOTE_B6, 0, 0,
          //this bit here does not work, same as above
	  tempo = {
	    12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12,
	    9, 9, 9, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12,
The notes are defined in the Songs class, each one has a value
In my sketch, I want to do the following:
//initialisation is performed outside setup and loop
Song supermario("sm");
Player player;
When pressing a button, it should work like this:
//this goes in the loop
player.play(supermario.melody, supermario.tempo);
It seems like my problem is the array initialisation in the constructor given a certain parameter to the constructor itself.
Can someone point me in the right direction to achieve this?
I would appreciate to know as well if this is the right way of doing it, or there is a better approach.
Thanks in advance!
Maybe something like this will work:
Songs.h
class Songs{
  public:
	const int *melody;
	const int *tempo;
Songs.cpp
static const int sm_melody[] = {
static const int sm_tempo = {
Songs::Songs(char title[]) {
  if (strcmp(title,"sm") == 0) {
    melody = sm_melody;
    tempo =  sm_tempo;
    // NO MATCHING SONG TITLE FOUND
Make the data members 'private' and manipulate them in the constructor or add 'public' setter and getter functions?
Thank you very much everyone for you help!
I'll try your suggestions, see how it goes and let you know!
paahaa:
Be warned that the 'player' object has no way of knowing how many notes are in the melody. I expect you will find that you have to get that value from somewhere and pass it to the player. The Songs object will have to store the number of notes because it is the only place that the value is easily determined.
