Initialization of object values ​​out of function does not work
Hi. I have a problem with initializing values out of function. When I create an object in a function it works correctly, but I can not call it from other functions but if I create it out of function it does not pass the values to the object and then when I give the function “printIt ()” it will write zero for all values.
ASR.ino
#include "AdvancedSR.h"
#define dp 3 //DATAPIN
#define lp 10 //LATCHPIN
#define cp 6 //CLOCKPIN
int NOS =3; //NUM OF SHIFT REGISTERS
AdvancedSR btn(dp,cp,lp,NOS);
  btn.printIt();
void loop(){
 btn.printIt();
AdvancedSR.h
#ifndef advancedsh_h
#define advancedsh_h
#include "Arduino.h"
class AdvancedSR
  public:
  AdvancedSR(int DataPin,int ClockPin,int LatchPin,int NumOfSR);
  void printIt();
  void ShiftIn(int INPin);
  bool SInOn[];
  int DP;
  int CP;
  int LP;
  int NOSR;
#endif
AdvancedSR.cpp
AdvancedSR::AdvancedSR(int DataPin,int ClockPin,int LatchPin,int NumOfSR){
  DP = DataPin;
  CP = ClockPin;
  LP = LatchPin;
  pinMode(DP,OUTPUT);
  pinMode(LP,OUTPUT);
  pinMode(CP,OUTPUT);
  NOSR=NumOfSR;
  for( int x = 0;x<=(NOSR*8);x++){
    SInOn[x]= false;
void AdvancedSR::printIt(){
  Serial.println(String(DP)+" "+String(CP)+" "+String(LP)+" "+String(NOSR));
void AdvancedSR::ShiftIn(int INPin){
  int x = NOSR;
  uint64_t BITS = 1;
  for(byte y = 0;y<(x*8);y++){
    digitalWrite(LP,LOW);
    for(byte nosW = NOSR;nosW>=1;nosW--){
      shiftOut(DP,CP,MSBFIRST,BITS>>8*(nosW-1));
    digitalWrite(LP,HIGH);
    SInOn[y]=digitalRead(INPin);
    BITS*=2;
    delay(1);
    Serial.println("CIL");
  for(int l = 1;l<=NOSR;l++){
    shiftOut(DP,CP,MSBFIRST,0);
you can't work with the hardware api before setup (). it is not intialized. add init or begin function to your class and call it in setup
I created the “begin” method but it does not work anyway.
ASR.ino
AdvancedSR btn;
  btn.begin(dp,cp,lp,NOS);
void loop(){
 btn.printIt();
AdvancedSR.h
class AdvancedSR
  public:
  void begin(int DataPin,int ClockPin,int LatchPin,int NumOfSR);
  AdvancedSR();
  void printIt();
  bool SInOn[];
  int DP;
  int CP;
  int LP;
  int NOSR;
#endif
AdvancedSR.cpp
void AdvancedSR::begin(int DataPin,int ClockPin,int LatchPin,int NumOfSR){
  DP = DataPin;
  CP = ClockPin;
  LP = LatchPin;
  pinMode(DP,OUTPUT);
  pinMode(LP,OUTPUT);
  pinMode(CP,OUTPUT);
  NOSR=NumOfSR;
    SInOn[x]= false;
AdvancedSR::AdvancedSR(){
  init();
  int x = NOSR;
  uint64_t BITS = 1;
    BITS*=2;
    delay(1);
  bool SInOn[];
    SInOn[x]= false;
Writing to a zero element array seems wrong to me.
But how to use array in class
Your misconception is not related to classes at all.
You should not read or write outside array bounds, but C++ will not stop you from doing it.
You will probably get a warning if that was enabled.
In C++ arrays are just collections of elements of the same type sitting side by side in memory,
there is no builtin mechanism for automatic allocation (besides arrays on the stack) or size changes.
Study arrays and how to work with dynamic allocated arrays in a C++ tutorial.
MenTom_CZ:
same as in struct
bool SInOn[S_IN_COUNT];
WARNING: Your object doesn’t have a .init() function so what is being called in the constructor? It can’t be .begin() which has to be called in setup() so it is AFTER the Arduino runtime is initialized.
ERROR:  for( int x = 0;x<=(NOSR*8);x++){
That should be “x < (NOSR*8)” or you will go off the end of your array. Indexes start at 0 and end at size-1.
If you don’t know the size of the array until the object is constructed I think one way is to make the member variable a pointer and dynamically allocate the memory in .begin(). This requires a ‘destructor’ function to clean up.
ASR.ino
AdvancedSR btn;
void loop(){
 btn.printIt();
AdvancedSR.h
class AdvancedSR
  public:
  AdvancedSR();
  ~AdvancedSR();  // Destructor needed to free allocated memory
  void printIt();
  bool *SInOn;  // Allocated memory for array of bool
  int DP;
  int CP;
  int LP;
  int NOSR;
#endif
AdvancedSR.cpp
  DP = DataPin;
  CP = ClockPin;
  LP = LatchPin;
  pinMode(DP,OUTPUT);
  pinMode(LP,OUTPUT);
  pinMode(CP,OUTPUT);
  NOSR=NumOfSR;
  SInOn = new bool[NOSR * 8];
    SInOn[x]= false;
  init();
AdvancedSR::~AdvancedSR(){
  delete [] SInOn;
  int x = NOSR;
  uint64_t BITS = 1;
    BITS*=2;
    delay(1);
