initializer but incomplete type error
I am using 1.0.5. I have loaded a sketch which calls a number of library programmes I have used a similar sketch which does not throw up errors. The sketch is sensornet an NRF24 mesh program written by maniacbug.
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
  • Example of a sensor network
  • This sketch demonstrates how to use the RF24Network library to
  • manage a set of low-power sensor nodes which mostly sleep but
  • awake regularly to send readings to the base.
  • The example uses TWO sensors, a ‘temperature’ sensor and a ‘voltage’
  • sensor.
  • To see the underlying frames being relayed, compile RF24Network with
  • #define SERIAL_DEBUG.
  • The logical node address of each node is set in EEPROM. The nodeconfig
  • module handles this by listening for a digit (0-9) on the serial port,
  • and writing that number to EEPROM.
#include <avr/pgmspace.h>
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
#include <Tictocs.h>
#include <Button.h>
#include <TictocTimer.h>
#include “nodeconfig.h”
#include “sleep.h”
#include “S_message.h”
#include “printf.h”
// This is for git version tracking. Safe to ignore
#ifdef VERSION_H
#include “version.h”
#else
#define TAG “Unknown”
#endif
// Pin definitions
#ifndef PINS_DEFINED
#define PLATFORM “Getting Started board”
// Pins for radio
const int rf_ce = 9;
const int rf_csn = 10;
// Pins for sensors
const int temp_pin = A2;
const int voltage_pin = A3;
// Pins for status LED, or ‘0’ for no LED connected
const int led_red = 0;
const int led_yellow = 0;
const int led_green = 0;
// Button to control modes
const int button_a = 4;
// What voltage is a reading of 1023?
const unsigned voltage_reference = 5 * 256; // 5.0V
#endif
RF24Network network(radio);
This is the line which causes the error.
I cannot find any solutions to this problem In truth I do not know what a initializer is and type is not explained in arduino reference. Any help would be appreciated
Have you declared 'radio'
RF24 radio(9,10);
http://maniacbug.wordpress.com/2011/11/02/getting-started-rf24/
One problem is the ZIP file does not contain all the latest files
RF24.cpp and RF.h
roger
