I worked my way through creating a library, and can now successfully include it.
This one is for LEDs--uninteresting, but a useful step on the way to relay management.
I create both a base dhDevice class and then a dhLed class:
#ifndef Test_h
#define Test_h
#include "Arduino.h"
class dhDevice
public:
dhDevice();
class dhLed: dhDevice
public:
dhLed(byte thePin);
//void init(byte outPin);
bool status();
void turnOn(unsigned long turnOffTime=-1);
void turnOff();
unsigned long offTime();
void update();
byte pinReport();
private:
bool myStatus=false;
unsigned long myOffTime;
byte myOutPin;
#endif
and
// dhMegaLib. dochawk's library of useful things for atMega projects.
// Copyright MMXIX
// a root device class from which to derive others
#include "dhMegaLib.h"
dhDevice::dhDevice(){}
dhLed::dhLed(byte thePin) : myOutPin(thePin){ }
void dhLed::turnOn(unsigned long turnOffTime){
digitalWrite(myOutPin,HIGH);
if (turnOffTime<-1){
myOffTime=turnOffTime;
//set to leave on indfinitely
myOffTime=-1;
void dhLed::turnOff(){
myStatus=0;
unsigned long dhLed::offTime(){
return myOffTime;
void dhLed::update(){
//update the current lights
//for the moment, this assumes millis() will never overflow
if( (myStatus==true) && (millis()>=myOffTime)) {
turnOff();
byte dhLed::pinReport() {return myOutPin;}
These were done with vi, so the formatting may be a bit different than usual.
And then a simple sketch to load them up:
dhLed myLeds[2]=(5, 6, 7);
Serial.println("begun");
for (byte i = 0; i <= 2; i++) {
Serial.print(i); Serial.print(": "); Serial.println(myLeds[i].pinReport());
But when I check the serial monitor, I get
begun
0: 7
1: 7
2: 0
I would expect, however, to see 5,6,7.
I'm betting that I'm missing something rather basic here . . .
