Initializing INT1 and TIMER2 freezes the program
https://forum.arduino.cc/index.php?topic=650716.0
I will put the code again
#include <EEPROM.h>
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include <ir_Lego_PF_BitStreamEncoder.h>
#define setbit(port, bit) (port) |= (1<< (bit))
#define clearbit(port, bit) (port) &=~(1<< (bit))
#define POWER_LED_ON() clearbit(PORTD, PD7)
#define POWER_LED_OFF() setbit(PORTD, PD7)
uint8_t table[10] = {141, 125, 109, 94, 78, 62, 47, 31, 16, 1};
const int iRReceivePin = PD2;
IRrecv irrecv(iRReceivePin);
decode_results results;
/* iniialise speed to zero, and also store the set value in EEPROM
  on every change to be read from it on power recycle.
char speedVal = 0;
char num = 0;
uint8_t fan_on = 0;
uint8_t lastPowerState = 0;
  initialize();
  //Initialize the zero crossing detector INT(1)
  MCUCR |= ((1 << ISC11) | (1 << ISC10)); //INT in Rising edge
  GICR |= (1 << INT1);      //Enable INT1
  //Set Timer 2
  TCCR2 |= (1 << WGM21); //CTC
  TIMSK |= (1 << OCIE2); //Enable OCI2
  sei();
  //Zero Crossing Detect.
    ISR(INT1_vect)
      if (!fan_on)
        PORTD |= (1 << PD5); //High = TRIAC Off
        return;
      if (9 == speedVal)
        PORTD &= (~(1 << PD5)); //low = TRIAC ON
        return;
      OCR2 = table[speedVal];
      TCCR2 |= ((1 << CS22) | (1 << CS21) | (1 << CS20)); //Start Timer prescaler =1024
      TCNT2 = 0x00;
    ISR(TIMER2_COMP_vect)
      TCCR2 &= (~((1 << CS22) | (1 << CS21) | (1 << CS20))); //Stop Timer
  while (1)
    if (irrecv.decode(&results)) {
      switch (results.value)
        case 0xFF48B7:  // NEC code for UP Key
            if (speedVal < 9)
              speedVal++;
            Display (speedVal);
            EEPROM.put(5, speedVal);
        case 0XFF609F:  //NEC Code for DOWN Key
            if (speedVal > 0)
              speedVal--;
            Display (speedVal);
        case 0xFFAA55:  // NEC code for enter key
            if (fan_on) {
              POWER_LED_OFF();
              fan_on = 0;
              lastPowerState = fan_on;
              EEPROM.put (3, lastPowerState);
              POWER_LED_ON();
              fan_on = 1;
      irrecv.resume(); // Receive the next value
/* Seven Segment Display Function */
void Display(char num)
  if (num > 9)
    return;
  switch (num)
    case 0:
      PORTC = 0B00000000;
      PORTB = 0B00000010;
    case 1:
      PORTC = 0B00111001;
      PORTB = 0B00000010;
    case 2:
      PORTC = 0B00100100;
      PORTB = 0B00000000;
    case 3:
      PORTC = 0B00110000;
      PORTB = 0B00000000;
    case 4:
      PORTC = 0B00011001;
      PORTB = 0B00000000;
    case 5:
      PORTC = 0B00010010;
      PORTB = 0B00000000;
    case 6:
      PORTC = 0B00000010;
      PORTB = 0B00000000;
    case 7:
      PORTC = 0B00111000;
      PORTB = 0B00000010;
    case 8:
      PORTC = 0B00000000;
      PORTB = 0B00000000;
    case 9:
      PORTC = 0B00010000;
      PORTB = 0B00000000;
void initialize()
  irrecv.enableIRIn(); // Start the IR receiver
  /*  PD7 as output  */
  POWER_LED_OFF();
  DDRD |= (1 << PD7);
  /* Set PD2 and PD3 as inputs */
  DDRD &= ~(1 << PD2);
  DDRD &= ~(1 << PD3);
  // Port C pins 0 to 5 as output for seg a b c d e f
  // Port B pin 1 as output for segment g
  DDRC |=  (1 << PC0) | (1 << PC1) | (1 << PC2) | (1 << PC3) | (1 << PC4) | (1 << PC5);
  DDRB |= (1 << PB1);
  /* Sets all segments a to g in the display off */
  setbit (PORTC, PC0);
  setbit (PORTC, PC1);
  setbit (PORTC, PC2);
  setbit (PORTC, PC3);
  setbit (PORTC, PC4);
  setbit (PORTC, PC5);
  setbit (PORTB, PB1);
  EEPROM.get (5, speedVal);
  Display (speedVal);
  EEPROM.get (3, lastPowerState);
  fan_on = lastPowerState;
  if (lastPowerState) {
    POWER_LED_ON();
  else  {
    POWER_LED_OFF();
  /*  Output - blocking gate signal to opto isolator */
  setbit(PORTD, PD5); //PD5 High = Triac off
  DDRD |= (1 << PD5); //set DDR for port BIT 5
where can the problem be?
Thanks in anticipation.
IRrecv uses Timer2.
cattledog:
IRrecv uses Timer2.
Thanks cattledog. Couldn't have fathomed this in my lifetime!
Since I need to use a timer in CTC Mode will use Timer1 (More complexity though)
I have used PB1 to drive the segment g in the display will I need to change this as alternate definition for PB1 is for Output Capture 1A (OC1A)?
