I'm trying to load a bit map image from the on board SD card of a 3.5" TFT display. I get an error message that the initializing has failed. I've tried using the methods from a couple of the examples, YouTube videos and a past project, just can't get it right. At this point I don't know if I have something wrong or if I actually have the logic to initialize.
The display is communicating with a Nano Every via SPI. The sketch below has most of the loop logic commented out, I want to concentrate on loading the bit map, once it's working I'll add that as the last case of the switch function.
The SD card is formated as FAT32 with a single file "sunrise.bmp" on the root.
Here is the sketch
// mp3 player with TFT display
// Cycles through circles, and verses sync'd with song
// With Bit map image at end
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
#include <SD.h>
#include <SPI.h>
// These are 'flexible' lines that can be changed
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
#define SD_CS 7
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define MAX_BMP 10 // bmp file num
#define FILENAME_LEN 20 //Max filename length
File bmpfile;
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
char *verse[] = {"zero", "one", "two", "three", "four"};
byte verseNumber = 1;
const unsigned long verseChange = 2000;
unsigned long markTime = millis();
unsigned long currentTime;
long int test = 0;
char *color[] = {BLACK, BLUE, RED, GREEN, CYAN, MAGENTA, YELLOW, WHITE};
byte colorNumber;
int unsigned long verseDly[20];
int verseDlyIndx;
tft.begin();
tft.fillScreen(BLACK); //clears screen, sets to Black
tft.setRotation(3); // rotates screen 90' for landscape mode
tft.setTextSize(2);
// delays between verses
verseDlyIndx = 1;
verseDly[1] = 23000;
verseDly[2] = 27000;
verseDly[3] = 37000;
verseDly[4] = 28000;
verseDly[5] = 27000;
verseDly[6] = 15000;
verseDly[7] = 11000;
verseDly[8] = 32000;
verseDly[9] = 32000;
verseDly[10] = 1000;
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("failed!");
else Serial.println("OK!");
bmpDraw("sunrise.bmp", 0, 0);
} // end setup
// cycle through verses
currentTime = millis();
//Serial.print("verseNumber =");
//Serial.print("\t");
//Serial.println(verse[verseNumber]);
// fill screen with circles
if(verseNumber == 1){
circles();
// Verse delays
if ((currentTime - markTime) > verseDly[verseDlyIndx])
verseNumber ++;
verseDlyIndx ++;
Serial.print(verseNumber);
Serial.print("\t");
Serial.println(verseDlyIndx);
switch (verseNumber)
case 1:
tft.fillScreen(BLACK); //clears screen, sets to Black;
circles();
case 2:
tft.fillScreen(BLUE); //clears screen, sets to Black
tft.setTextColor(CYAN);
// Print verse 2
tft.setCursor(10, 70);
tft.print("Every day is so wonderful");
tft.setCursor(10, 100);
tft.print("Then suddenly it's hard to breathe");
tft.setCursor(10, 130);
tft.print("Now and then I get insecure");
tft.setCursor(10, 160);
tft.print("From all the pain");
tft.setCursor(10, 190);
tft.print("I'm so ashamed");
case 3:
tft.fillScreen(MAGENTA); //clears screen, sets to Black
tft.setTextColor(BLACK);
// Print verse 3
tft.print("I am beautiful no matter what they say");
tft.print("Words can't bring me down");
tft.print("I am beautiful in every single way");
tft.print("Yes, words can't bring me down, oh no");
tft.print("So don't you bring me down today");
case 4:
tft.fillScreen(RED); //clears screen, sets to Black
tft.setTextColor(WHITE);
// Print verse 4
tft.print("To all your friends you're delirious");
tft.print("So consumed in all your doom");
tft.print("Trying hard to fill the emptiness");
tft.print("The pieces gone, left the puzzle undone");
tft.print("Is that the way it is?");
case 5:
tft.fillScreen(CYAN); //clears screen, sets to Black
// Print verse 5
tft.setCursor(10, 50);
tft.print("You are so beautiful");
tft.setCursor(60, 70);
tft.print("no matter what they say");
tft.print("Words can't bring you down, oh no");
tft.print("you are so beautiful");
tft.setCursor(60, 150);
tft.print("in every single way");
tft.setCursor(10, 180);
tft.print("Yes, words can't bring you down, oh no");
tft.setCursor(10, 210);
case 6:
tft.fillScreen(GREEN); //clears screen, sets to Black
// Print verse 6
tft.print("No matter what we do");
tft.print("(No matter what we do)");
tft.print("No matter what we say");
tft.print("(No matter what we say)");
tft.print("We're the song inside the tune (Yeah)");
tft.setCursor(10, 220);
tft.print("Full of beautiful mistakes");
case 7:
tft.fillScreen(WHITE); //clears screen, sets to Black
tft.setTextColor(MAGENTA);
// Print verse 7
tft.print("And everywhere we go");
tft.print("(And everywhere we go)");
tft.print("The sun will always shine");
tft.print("(The sun will always, always shine)");
tft.print("And tomorrow we might wake up");
tft.setCursor(60, 210);
tft.print("on the other side");
case 8:
tft.setTextColor(BLUE);
// Print verse 8
tft.print("'cause we are beautiful");
tft.print("Yes, words won't bring us down, no, no");
tft.print("We are beautiful in every single way");
case 9:
tft.fillScreen(YELLOW); //clears screen, sets to Black
// Print verse 9
tft.print("Ooh-oh-oh,yeah");
tft.print("Don't you bring me down today");
tft.print("Yeah, ooh");
tft.print("Ooh,today");
default:
} // end switch
} // end ((currentTime - markTime))
} // end loop
void circles() {
tft.fillCircle(random(0,480), random(0,320), random(10, 40), color[random(1, 8)]);
delay(250);
} // end void circles
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.print(F("Loading image '"));
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.print(F("File not found"));
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print(F("Image size: "));
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
// Set TFT address window to clipped image bounds
tft.startWrite(); // Start TFT transaction
tft.setAddrWindow(x, y, w, h);
for (row=0; row<h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
tft.endWrite(); // End TFT transaction
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
tft.startWrite(); // Start new TFT transaction
for (col=0; col<w; col++) { // For each pixel...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format, push to display
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
tft.pushColor(tft.color565(r,g,b));
} // end pixel
} // end scanline
tft.endWrite(); // End last TFT transaction
Serial.print(F("Loaded in "));
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File &f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File &f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
Thanks for any help and comments
John
